Any of the high end Yokohamas. Myself and two other mates use nothing but. They run ES100s, and I run the C.Drives.
I also previously ran the A539s... All are very good in the dry, and also pretty damn good in the wet.
i got a set of 245/40/r18 Falken ZE326 and must say they are pretty f**ken useless in the wet i feel like im seriously skating on ice when i drive in the wet (complete granny driving aswell) how ever in dry they do the job well enough :)
-Ruffels
I have toyo T1S (255/40/17) on the rear (replaced by the T1R) and Maxxis MA-Z1 on the front (235/45/17). The Maxxis are sensational, especially conisdering the price. Great in the wet and pretty good in the dry. The Toyo has almost an identical tread pattern and seems to exhibit similar charateristics. Probably dopnt grip as well in the dry as i would like. But thats no to much of a worry.
The thing about the Maxxis is that they dont come in a 255 width at the moment. No idea on wear rates yet. But the maxxis on the front have done 2 motor challenge days and are holding up well.
Hey Missinglink,m
Where did you get your Maxxis from?
So far I've only found Bob Jane stocks them and the guy I spoke to (Grant from Reynella, SA) said they only had MA-V1 and quoted me prices for these. He said the MA-Z1 were available but in limited sizes in Australia and he wasn't able to quote me any prices on these.
There was a set of [new] Kelly Chargers on my GTSt when I got it, just been complied.
Tread looked OK, compound felt OK. I only put up with them for less than 1000k.  If you ever come across a tyre dealer giving them away for free - Don't take them,unless you have a death wish  { I sold them to a bloke with a Commodore.}
i agree they are the worst tyre i have ever driven on
if any people here think a ziex 326 is bad, i challenge you to try driving with kelly chargers, they redefine 'no grip'
326's are like semi slicks when compared to chargers, they ARE that bad.
wet and dry rating -100/10
My favourites on both Skylines and RX7s are Falken FK451s and Kumho Ecstas. Both are excellent in wet and dry. I've also got a set of F1s on a Skyline as well - and although I'm happy with the performance I think they're overpriced compared with the Falkens and Kumhos. They certainly don't perform better.
Sizes 235/45r17 front 255/40r17 rear. Power not too sure but last time the Skyline GTSt was on the RR it was 250hp at the wheels. Add to that 75hp nitrous and 10% toluene in the fuel should make that higher and I've had no issues.
:wassup: My goodness they must be bloody awful to be worse than ziex 326. Where are they made?
I know that some of you have tried fedrals i have some on the rear of my 33 GTST there 18/265/35 and i think that they are not bad i have 216rwkw so it not really stock but even with out the camber kit they hook up really well dry that is i havent had them in the wet yet, and i run way to much neg camber so after the camber kit they should be reall good
Hi guys
Can anyone tell me more about the Hankook K104 ($165) ????
Also about the difference in performance between Toyo TPG ($180) and Proxes T1R ($295).
I'm due for a tyre change and the above are looking like good value for money options. size required 235/45/r17
Thanks
Sumitomo HTRZ II
Dry: 2/10
Wet: 9/10
Value for money: 3/10
These tyres in the dry are shocking for traction. but in the wet the are the other way around.
The actually spin easier in the dry then what they do in the wet ???
Not the best tyre for handling, But would be good for drift. Is also a good tyre for high speed. from my experience.
Although the cost is fairly expensive, around $400 - 450 per tyre if I remember correctly.
Dunlop Sport 2000
Dry: 4
Wet: 4
Value: 4
OEM tyres for my last car. Typical OEM tyre: quiet and reasonable in wet and dry, cold and warm. Not much of a sports tyre, though.
Silverstone Something, who cares
Dry: 4
Wet: 3
Value: 3
Silverstone make some of the crappiest tyres on the planet. Every person I know who's used them has hated them; no grip and wear quickly
Pirelli P5000 Drago
Dry: 5
Wet: 6
Value: 6
These are a good wet weather tyre. Two big centre channels and directional tread. I found myself doing Old Pac in the wet only 5-10km/hr slower than in the dry. Even though I had them for longer than the Silverstones, when I had to swap 2 out due to puncture the Pirellis still lasted longer than the Silverstones I replaced them with.
Falken Azenis RT215
Dry: 7
Wet: 4
Value: 5
Everyone knows about these tyres. Didn't last long, but I could hammer my car and the thing would just stick. In the wet you noticed the lack of tread blocks, but in the dry I was finding myself taking corners flat that I'd normally have to lift on. Shame about the tyre life.
Bridgestone Potenza RE040
Dry: 5
Wet: 5
Value: 5
OEM tyres on my current ride. Great OEM sports tyre. Progressive, and with a reasonable amount of grip even when cold. They also do OK in the wet. The only problem is they can't handle heat. The first time I took them to the track, I baked them and they didn't grip properly cold after that. I'd get a fair amount of slip until I got heat into them.
Falken Azenis RS-V04
Dry: 8
Wet: 2
Value: 4
Ignore what some people tell you, Formula R semi slicks are not daily drivable. They were noisy as hell, and only by babying them did I get 8000kms out of them. I'd average one oversteer moment per drive in the wet, and they'd pick up stones and either embed them into the rubber or flick them up onto cars behind you.
But, in the dry and in anger, a Formula R tyre redefines what you think your car can do around a bend. I had a couple of situations where I went into a corner too hot and I thought I'd slide out; on these tyres the car just did what it was told. And, on the track, they'll do it lap after lap.
Definite "second set of rims" rubber. There are better Formula R tyres out there, but not for the pittance I paid for them.
Dunlop Direzza DZ101s
Dry: 6
Wet: 8
Value: 7
Current tyres. In the dry they provide good grip (at least as good as the RE040s, if not better) and in the wet they're phenominal. I can't believe how much grip I can get, even in standing water, and even when they let go its progressive and its easy to bring them back on line.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
