Edited list below, just add what you do if you like in a post and i'll re-edit it to include you.
it just occured to me guys, there are a lot of us, locally, that are in a variety of different fields in the workforce.
how about a local thread for the members where we can post up what we do for a living. Im not suggesting mates rates or any kind of remuneration at all, but if any of us ever need advice on certain topics then we can ask local members for their help and advice.
e.g if we need info on bikes we know to ask Jayce, for info on electrical products we can ask (i forgot his board name but he works in electrics at domayne)
For learning on how to be the worlds greatest hunk we can ask Veilside etc....
we can have a list and it can be edited by the threads creator (most likely me) constantly so we can have a quick list for reference and help.
LIST:
VeilsideR33= Real estate agent
R31DET= ex car detailer and car artist, works for Ingrams Auto Electronics & Air conditioning
Supaflyskyline= electrician
R31_Silo2= Jeans west
4PKNUP= Target (the T is silent)
Terminal= Engineer
Amaru= Network Engineer
NJR 34GTT= IT Specialist with IBM
Bluprint= Web developer
Stevie= Public relations
Frink= ABC T.V and film and T.V guru
Oscar32= Child psychologist
OZR32GTR= IT Consultant
Leech_ = Network engineer
Sauce= Coles and studying 3D
Race_snooze= IT and ex Air-conditioning tech
skyGTRline= Southers ****
djhatton= Electrical section at domayne
bambinator= Doctor at Canberra Hospital
Anakha= Royal Australian Air Force
Yeti= Lawyer
Biancardi= Tiler
Marc2= Owner of dicount tyre service, Belconnen and Gunghalin and they are also authorised inspection stations, call 62515977 and ask for Mark. Fitter and turner, Mechanical & electrical engineer
SKYLVIA (Beau)= Electronics boutique
Matski= Commercial broadcaster
Noony= I.T security
LTSJayce= Athletes foot - Belconnen
Edited by Veilside R33
https://www.sau.com.au/forums/topic/74751-how-bout-an-sau-act-business-thread/
I work for the government.
I do admin side of building maintanence, for 8 buildings. So currently I will put my hand up for being a bum.
I am going to get a new job in October, and that will make me a mechanic, or at least try to be one
Finished my Engineering Degree at ANU last year, still looking for work as i took a bit of time off last summer
so does that mean you could engineer my car if it required it? this could be very handy indeed.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
