  • 2 months later...
Hey guys will be launching my new buiness in September starting out as group fitness and personal training and in march expanding to massage therapy and nutrition later next year, slowly adding services eventually adding physiotherapy and stuff when I finish uni :-) www.melhealthandbody.com yippee!
  • 4 weeks later...
What a great thread :)
I run a small online based business selling Car Audio gear (High Fidelity Audio), website will be hosted in about 3 weeks, so i've barely begun. I can sort out home audio and DIY gear too, as well as little bits and pieces like voltmeters etc. I will be sure to post back when my website is up.
Thanks all!
  • 3 weeks later...
Hey chaps..
I are started a business n shizle.
www.andrewsrcengines.com
Website is still being added too...so if you need anything I can get most stuff...mainly engines but can get boats and aircraft kits if needed.
  • 4 weeks later...
Hey Dude,
I don't know what you were quoted but either way it'll be expensive.
there are 3 componets here.
*The Fan
*The main shroud over the radiator and above the fan
*and the smaller clip on peice below the fan
All together i can do for about $425
I can get the fan pretty easily but the two shroud components will have to come from japan.
Cheers
Jimmy
how much is just the fan?
  • 1 month later...
Hey zebra, I don't need an RC engine but can I pay you to clean my RC car? Thing is filthy and the carb is all gummed up so it doesn't pull fuel through unless my finger is over the exhaust... I'd do it but I really CBF haha. It's a Thunder Tiger MT4 S50 (the big bore engine one).
  • 4 weeks later...
Hey all,
IT Apprentice in the APS here - can help out with any and all computer problems, provide advice on getting bits n pieces. Work in the City near the casino. Give me a buzz if you need/want anything.
Cheers.
I spose I might as well post in here too...
For all of your snowboarding, wakeboarding or waterskiing needs come check out my shop!
Deja Vu Canberra
129 Newcastle St Fyshwick
(easy to spot for SAU members coz there's always a 32 parked right out front lol)
10% off anything in store for all SAUers - just be sure to mention you're from here coz I don't know anyone's faces yet - I'm the guy with glasses who almost always wears a beanie :D
Cheers guys,
Drew
  • 3 months later...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
