can i please have my account totally removed from this site i dont want it anymore. thanks
We don't normally remove accounts sorry mate, your easiest bet is simply to not use your account if you don't want it any more.
can i please change my name to jimmys-33T
cheers
Sure can!
Hi, sorry to be a pain but i no longer own my tx3 (havent for over a year) and its kinda stupid to have the username of my old plates. So is there a possibility of changing it to "SkyHi_ECR33" pleeeeeaasee :P
Edited by tx3_90
Hi, sorry to be a pain but i no longer own my tx3 (havent for over a year) and its kinda stupid to have the username of my old plates. So is there a possibility of changing it to "SkyHi_ECR33" pleeeeeaasee :thumbsup:
oh whoops, lucky i checked... I edited wrong, wanted "SkyHi_33" thanks :)
thank you very much! :(
You're most welcome ;)
May I please have my user name changed to --Grandma R31--
could you change my username to
YCOPY
Thanks
Scotty
back to: 'BAMR33' please
I sold my VLCT so no point having my user name this one anymore LOL.
Can my new user name please be 'Weezy' if not avaliable can you please PM me Revhead :blush:.
Thanks. Wayne.
All done guys :(
