Hi There,
I would like to change my current username from Tarmac Kermit( name based on my tarmac rally green R32 GTR)
to r32gtrdrc if possible..
I put kermit into a concrete wall at the last sposors day for targa west a few months ago and am now building a new R32 GTR for targa rally tarmac events( this one wont be green..)
Hi please change my name to "adams14" thanks!
Please change to:
Dan_34gtr
Cheers.
hi can i get mine changed to s33gtr thanks
Hey mate name change to "Captain Natro"
Hi can you please change my username to GATE31, thanks!!
Hello,
Please change my username to "WgnZilla"
Thanks
can i please get my name changed to dorifto13, thank you :)
All done!
Hi There,
cheers post-74499-0-59191200-1350564881_thumb.j
Could you please change mine from 'ishgtr' to 'ishyz34'
could you please change my name to 'the spruce moose'. Thanks
hey guys. first post here. i made this account aggeeees ago and just validated it. I need it changed to "RZ86". Thanks :)
Hi ADMIN, got new plates so can you change mine to YE34OK? Cheers
Hey guys time for a name change after a good couple of years! Can you please to change my name to Hakosuka22. Thanks in advance!
Please change my Username to whtbox. Thanks
please change to:
3LGODZILA
thanks !
can you change me to AngryRBGTX please?
:) thankyou in advance..
All done!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
