Hi There,
I would like to change my current username from Tarmac Kermit( name based on my tarmac rally green R32 GTR)
to r32gtrdrc if possible..
I put kermit into a concrete wall at the last sposors day for targa west a few months ago and am now building a new R32 GTR for targa rally tarmac events( this one wont be green..)
Hi please change my name to "adams14" thanks!
Please change to:
Dan_34gtr
Cheers.
hi can i get mine changed to s33gtr thanks
Hey mate name change to "Captain Natro"
Hi can you please change my username to GATE31, thanks!!
Hello,
Please change my username to "WgnZilla"
Thanks
can i please get my name changed to dorifto13, thank you :)
All done!
Hi There,
cheers post-74499-0-59191200-1350564881_thumb.j
Could you please change mine from 'ishgtr' to 'ishyz34'
could you please change my name to 'the spruce moose'. Thanks
hey guys. first post here. i made this account aggeeees ago and just validated it. I need it changed to "RZ86". Thanks :)
Hi ADMIN, got new plates so can you change mine to YE34OK? Cheers
Hey guys time for a name change after a good couple of years! Can you please to change my name to Hakosuka22. Thanks in advance!
Please change my Username to whtbox. Thanks
please change to:
3LGODZILA
thanks !
can you change me to AngryRBGTX please?
:) thankyou in advance..
All done!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
