Could i please get mine changed to OMGGTR
Done!
Also im a vic member display my purple shiz logo :)
You'll need to chase that up with the Vic club exec sorry mate, I have no way of confirming your club membership and the like. If they need a hand getting you put into the group by all means please let me know :)
Hi Admin, can I please change my username from "MR PHATT" to "MR Pat34" please? Thank you
Or even change to "Pat34" or even "Pat". Thank you
Done! Gave you your first option, let me know if you would prefer one of the others (though FYI "Pat" is already taken).
Done!
thanks, very happy with that Revhead. Cheers
Done!
oops, wrong quote. Thanks Revhead-very happy with that
Hi mods, Is it possible that I could get my username changed to a name that's already in use? They haven't been online for 11 years, and only went online for just over half an hour from when they signed up. I don't think they're coming back. Thanks.
PM me the details mate and I'll take a look.
Requesting ...
From "CARSICK" - to "M34N"
Thanks in advance!
Jaimi
Taken sorry!
  • 2 months later...
Heh too easy.
Just confirming for those who might be wondering, the "no profanity" thing for sigs and avatars extends to usernames too - Wasteland aside, this is still a family-friendly site.
  • 1 month later...
Do you still have access to the ISP email account linked to it? If so I can validate you manually.
Sorry didn't have notifications on so I missed this.
I don't believe so. I have access to a few, tried to 'recover' account already. Can advise what accounts I can access over a PM. But I'm not 100% sure what account was used.
  • 1 month later...
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
