Trust Power Extreme 2, fairly quiet on idle etc but really opens up when you put you foot down and has a nice note. Don't know who would sell them in Perth though, i can only point you in the direction of Advan Performance in Sydney who could ship one to you but i'd say shipping would be worth a bit.
I second the Trust PE2. It's got a great sound when you give it some loud pedal but is very sedate around town. To top it off its pretty easy to get hold of.
I bought mine from Advan as noted above and I'm certain they could ship you one to perth fairly cheaply.
I need something soon.
It cant be to loud, but it has to sound a bit meaty.
about a 3-4 inch outlet and inlet that can connect to my high flow cat.
local in perth would be a bonus but will to ship if it doesnt take long.
any suggestions?
i recommend a custom-made from your local exhaust shop - cheaper than an aftermarket one, exactly to your specifications, and everything about it will be brand new!
Also, the jap made ones hang too low... (defectably low)
I'd sugest something like one of Hi-Tech Mufflers bolt on systems if your worried about noise (legallity) of the system, they generally flow pretty well and are designed to meet the noise, emmissions and ground clearance/exhaust fitting ADR's.
you can check them out here
www.hitechmufflers.com
other that thet, i'd suggest finding a good local exhaust shop and getting one custom made to your requirements
This Trust PEII, at 3.5 inch would it be under 90db (legal?) and does it hang very low?
actually, has anyone got a 3.5 inch that is legal?
ive got a 3.5 inch tipped cannon with 3 inch straight through.... im 100% sure it ISNT legal lol, sounds the part but, thats all that matters to me, lucky where i live cops are idiots when it comes 2 jap imports... " duh a nishan skywhat??? " :whatsthat. hehehe, im screwed when one comes around that know stuff about import cars but lol, till then :)
Trust Power Extreme II's have 3in piping, sit close to the chassis, and come in at about 92dB @ 4800rpm (apparently). They're available at Autobarn for 900ish, or also from SAU trader BT-Revolution here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=75916
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
