I Suggest We Kick Out Anyone Who Buys These..
  • Replies 78
hahahahahaha na they are fully sick NOT.....
that would have to be one way to destroy the best ass end on the road hey....
they actuarlylook like one of those new REX tail lights, which are floating around trying to make all rex's look like skylines.....
I wouldn't be buying them if I had a 32 either.
The obsessive compulsive in me noticed that one light has 11 LEDs the other has 12 (in the one housing).
Wondering if this is because they are of different size or LED brightness etc etc.
You really cant judge it until its on the car with the covers on...
ah but flicking through the newest autosalon today i noticed something disturbing.... and R32 with those freakin tail lights on it with a wide b/k, b/k looks good, but those freakin tail lights.... ughck
Wierd that eh. Cant explain it. Are they different sizes then?
$400 is that cheap for rears?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
