  • Replies 393
FYI: My car is fixed. Wow looks like this thread is great... Too bad I missed out! Next time!
Oh I paid $15 and didnt go, do I get it back? Or get a laynard?  hehe... well just donate the $10 or $15 to SAU :D
We can send you one.
I must say that your car looked even better on the road....well done and congrats!
The R32 is non too shabby either, as I said prior, there is nothing like a track car that can hold their own with a show car!
thanks for the great weekend away guys! coming up from canberra, the three of us (R31DET, LTSjayce and me) decided to stay the night there.
the quality of cars was great and winners were well chosen. i didnt win an award (i never expected too), however i did win the raffle 1st prize, so i cant complain. count on us coming back next year with a couple more.
cheers
Merli or any of the organisers,
I have just spent 10 min on yahoo and google and could not find any ref to the Driver training day with Aaron Mcgill. Can you send me a contact number I to call and discuss?
Paul, try http://www.auto-motion.com.au/ :D
edit: just realised there is nothing there. his other site is http://www.aaronmcgillmotorsport.com/ nothing there on driver training, but aaron runs a top day. great guy and driver. i believe you can email at [email protected]
I just spoke to them. Im booked in, at Oran Park GP 22nd Nov 05 unless they can grab a cancelled date at the creek.
Kabab with cheese, the Aaron Phase 3 day sounds the same as a UAS day, no real formal instruction, but instructors on hand if needed.
Guest DIRTgarage
Stacey is keen to add a black R34 vpec II to the garage. We are ordering ours next month....if it looks as tough as yours i wont know which one to drive.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
