Can anybody that's upgraded their rear rotors on a c34 comment on what rotors they went with?
Supposedly the rda and dba rotors require machining...?
Would be nice if there was a direct fit (besides the stockies)
Cheers,
Adrian
r32/33/34 rears bolt on easily (whole setup, rotors + callipers)
but you are probably just talking about upgrading to new rotors
can't help you there
  • 3 weeks later...
I can confirm these 350z 324mm rotors (with dogbone caliper adapter) fits the S1 without many issues
http://www.conceptzperformance.com/Cart/description.php?II=882&Car_Type=300&UID=20110706225202121.45.157.163
a bit 'dodgy brothers' in the sense the dogbone is bolted on and caliper bolted onto the dogbone, but Boy do they work well.
tested at the track and stood up well to the braking pressures applied..... cut a few seconds of my previous best time as well.
What type did you get the turbo or non turbo type? how much did they cost to get over here? Unique autosport also has a set with 2 piece rotors that looks good
Cheers,
Adrian
In case anybody is interested in a direct replacement rear rotor for a S2 C34 - I got the RDA 7657s which does not require any machining.
http://www.boostcruising.com/forums/index.php?showtopic=757478
after reading that, it seems like the non brembo single calliper 350z brakes/murano brakes could be a good upgrade for s2c34/m35 people
324mmx28 and really cheap, only down side is that its only a single piston calliper but if you want to upgrade but don't want to spend $$$ on brembos/r34 brakes or have to buy/change wheels this could be a good solution
We have the early model non-brembo single piston 350z brakes. They are 296x24mm and are shit.
There is a later model one apparently - 320x 28 form late 05 onwards. Really, as an upgrade I wouldn't be looking at them.
But as you say - if you don't want new wheels/ trying to save $ it might be worth it to investigate.
Well I got the 33GTST fronts today to fit to the 25G. They are 295 X 30, 2 pot. So they should pull up the Stag when the turbo is fitted.Still sourceing rear sway bar, its RWD, and front strut brace.
That link also says 350z track is the non Brembo, but thats touring. Track has Brembo, which makes a good upgrade for M35s. Ironpaw has a set and he seems happy with them.
best bet is to pm iamhappy, he has a fwd 5 stud converted, vq35 running n15 (or maybe n14) pulsar so he knows a bit about nissans and a bit about vq's (but probably not all that much about vq25's)
So does bbenny and rosella. Spoolin is running akebonos from the 370z/v36...
I got my z33 brembo rears fitted yesterday, the bolts were a different pitch, other than that no issue. Should get the r34 brembo fronts fitted today, and the braided stainless lines. :)
R34 brembos are the same as the z33 ones aren't they?
Edited by ironpaw
Well they did not fit.:(. So they are going on to the RS4. But I need to get some M12 bolts which is not too hard but also need some sleeves to accommodate the smaller bolts.Anyone know where these can be got or have people had them made special???????????
Can anyone confirm if Z34 front brakes will direct bolt onto an NM35?
I'm looking at the non brembo brakes, so it's a 325mm x 28mm disc and single sided twin piston caliper. I can only run these due to the fact my new rims are an A disc face and they won't clear a 4 piston caliper :(
Edited by slippylotion
No they won't. You need adapters for z34/v36 akebonos. Spoolin runs those brakes but he bought the whole pkg from the us which came with the mounts.
The z34 brakes are 4 pots as well...if the ones you had didn't fit I doubt these will.
Unless you've made a typo and your referring to the z33 touring brakes?
Im looking at the non Akebonos, so I assume they are the touring?
From the pic the calliper mount bolts look a long way apart. Is this what Spoolin needed the adaptors for?
Different disk offset I think mate.
That also happens when trying to fit R33GTST to a 25G N/A RWD. However I do not know if a 25G RWD has the same front end as an N/A R33GTS RWD.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
