There is no certain way to just tell if they will fit. You can either take a wheel and fit it on a gtr you find to see if it fits, or lay the brakes down inside the wheel and try that way.
We can't say offset of + 20will fit, because it's mostly about the spoke shape. They will fit over the brakes ok, it's just the spoke clearance you should check.
Good price too.
+1 to alex
nothing to do with offset, all about back space
also, your looking for anything R34 (gtr or gtt)
i got mine through this guy
http://stores.ebay.com.au/Skyline-spares
was really cheap too (compared to what some ppl try and flog them off for (i paid $330 for calipers only)
http://stores.ebay.c.../Skyline-spares
So I guess the $300 I paid for R34 GT-t calipers, pads, clips, shims and an untouched set of rotors is pretty good then... :banana:
Hi All,
Does anyone upgraded the brake calipers on a NM35?..im looking just doing the front calipers, anything should be better than the standard single pot. Would the R32gts-t 4pot a straight bolt on? and would my standard rims fits? Theres alot of threads for brake upgrades on early Stageas but not much on later series2 NM35's. Cheers guys.
dont know about the GTSt brakes, but GTR brakes through the range bolt on. Some need collars on the bolts . cant remember which.
no, standard wheels will NOT fit on after an upgrade, except AXIS rims. and yes i have seen R32 GTR brakes under AXIS rims.
Pretty sure the consensus is that m35's have 14mm bolts like r34's so I'd go that way
Stock r34 gtt brakes are 310mm x 30mm
Gtr brakes will be slightly bigger at 324mm x 32mm but cost a fair bit more
Brembo rotors are 324mm x 30mm, not 32mm.
The only Skyline rotor that is 32mm wide is the R32 GTR with Sumitomo calipers (296mm x 32mm). You need to go to the Akebono 355mm rotor to get a 32mm wide rotor.
That's why I abandoned my original plans & went looking for R34 GT-t brakes.
For a daily driver; I couldn't see the benefit of spending a shiteload of cash to buy rotors that I then had to modify anyway, just for a few extra mm of dia.
I'm sure the Brembo's are pretty special; but for the dollars, they'd want to be.
@Daleo,
Hi, did you just upgraded the calipers from an r34gt-t? Im hoping just to do the same, dont want to spend too much on an upgrade.
What are you planning on doing with the car? If it's just going to be a road car, plenty of us are happy with slotted rotors and decent pads. My brakes didn't give up at Mallala last time I was out.
@Daleo,
Yep, not fitted yet; being stripped, coated & rebuilt atm.
Definitely one of the easiest bolt on upgrade without the expense of going Brembo.
Look around, it might take a while, but they come up cheap from time to time.
Well im not planning on turning the car into a racecar, it will be just a daily driven car. I felt the front calipers needing a little bit of beef, rather than a single pot. Its just me not wanting to spend too much on big brand names.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
