Well im not planning on turning the car into a racecar, it will be just a daily driven car. I felt the front calipers needing a little bit of beef, rather than a single pot. Its just me not wanting to spend too much on big brand names.
You really don't need to upgrade the caliper then. I'm running DBA 4000 series slotted rotors, and QFM HPX pads. No problems. Didn't even fade when I had it on the track. I've got braided brake lines and new fluid to go in, but no issues anyway.
If I was going to upgrade though, the Brembos or the Akebonos look the business.
Ive got a full set of r33 gtst (front & rear) calipers with bendix ultimates; if anyone is keen? Was going to put on my stag, but i went brembo f50, just looking for rear brembos now!
Price delivered to Melb?
Hi All,
Just for reference -
The 1998 S2 RWD Stagea RS uses an S14/S15 mcpherson strut front suspension setup. R33GTST or R33GTR brembo calipers and disks will bolt straight up with a minor modification to the dust shield and some R33GTST brake lines.
The R34GTST will not bolt up due to the fact that they use a larger bolt. You can drill out the hub to make them fit.
Cheers
Chris
the correct rotor can be purchased from Greenline:
Thanks for your enquiry. Pricing information as requested:
DIXCEL PD Disc Rotor (Front) WGNC34 RB25DET 99 AWD (3212013 PD): 14,553 yen (Special)
Shipping: 25,100 yen
TOTAL: 39,653 yen AU$515
DIXCEL SD Disc Rotor (Front) WGNC34 RB25DET 99 AWD (3212013 SD): 21,483 yen (Special)
TOTAL: 46,583 yen AU$605
Rotors are 290x28mm (Height: 49.2mm).
Dixcel are soon to have distributor open their doors (next month) in NSW so hopefully pricing is better.
Brembo rotors are 324mm x 30mm, not 32mm.
The only Skyline rotor that is 32mm wide is the R32 GTR with Sumitomo calipers (296mm x 32mm). You need to go to the Akebono 355mm rotor to get a 32mm wide rotor.
hhmm what are the akebono disc's worth i still have to do mine!!!
G'day,
I'm about due for a brake replacement/upgrade just wondering if some one could give me advice on the difficulty, or rather potential of f***ing something up when replacing the pads, and potentially rotors on an m35.
Tinkered plenty with other cars, but never brakes, trying to save myself some money.
Looking at the RDA slotted rotors and unsure of pads.
Cheers
G'day,
Cheers
Mate; it's pretty straightforward, if you're unsure, take a few pics before you pull everything apart and above all TAKE YOUR TIME.
RDA rotors are fine; I reckon the Remsa pads sold by GSL Rallysport (forum trader) are great value with an excellent heat range, although they are a little dusty. Still, I'd rather have brakes that work than clean wheels. ;)
GSL are great to deal with; I've ordered pads in the morning, and received them on my doorstep the next morning; from QLD to Blue Mountains NSW! Seriously quick service!
Thanks for the tips I've been looking at a few vids and writeups online, for different cars mind you, but they all seem to say that most cars are the same. Will I need a special tool or like a C clamp etc to push the piston out for the new pads? Is there a requirement to bleed the system after changing them etc
PS thinking of grabbing something like this in the near to distant future, http://www.ebay.com....=item27c8937848 Thoughts?
PPS any idea when you are doing your next run of braces :P
Cheers
Edited by NickM91
Cheers
A little G clamp can help with pushing back pistons; just remember to only remove one caliper at at time to push them back.
I don't generally bleed after changing pads; but if you can't remember when the last time it was done; it's probably time.
Those wheels actually don't look too bad, but the +45 offset is woeful; you want to be aiming around +30 or +20offset in an 18x8".
Maybe have a look at Varrstoen if you're keen for BBS style in decent width/offset?
I've been out of action this week due to a nasty case of man flu; but my latest lot of CrMo tubing has turned up, so in a week to a week and a half; I should have some ready to go out. I have a couple prepaid, and they will be getting priority.
It's probably time to bump the thread, and start working out how many I need to make.
I just fitted the DBA club spec 4000's all round with the new T3 slot design. New A1rm's on the front and HPX on the rear, thanks for the good price GSL. lol
Should be good to go for the next track day at PI once they are bed in, hopefully by the weekend too as I was thinking of heading down to Calder...
How do you find the A1rm's as a day to day proposition? Not too tough on rotors; noise?
I thought it was weird at the last track day, 4000 t3s and hpx pads all round, and the fronts were dusty as!
Rears were fine, couldn't notice any dust at all.
Only change I'm planning is finally fitting the braided lines and new fluid.
DBA 4000s are the cheapest rotors you can get that are actually made in Australia. Higher grade of metal should last longer than their street series or RDAs.
Hi All,
Is $300 for an R34 calipers a good buy?
Depends; are all the clips shims & pins in place; any pads, what about the mounting bolts? What kind of condition are the dust boots in?
Don't forget; you'll need a set of rotors, and ideally a fresh set of pads to go with them.
For missing shims; add $30 per caliper; new pads; $90 for decent ones; Rebuild kits $30-$50 per caliper. Rotors are $250ish a pair to start. It all adds up if you buy the wrong set.
If you're patient; sets of complete calipers with all pins, shims, bolts & pads AND serviceable rotors come up around $300-$350.
Comes complete with pretty much everything except the rotors, including courier.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
