I don't it will. I had to go +30 to clear my r34gtt brakes and I just cleared it by 5mm. Its all to do with offset of the wheel.
No, it's not.
You can have a low offset wheel with rubbish clearance due to the spoke design. 2 or 3 piece rims generally state a J type disc reference. While lower offset wheels are more likely to clear, it is not a guarantee.
Try to look at the rims on a r33 or 34.
I was looking at these but they only come in +40
http://www.ebay.com.au/itm/19-inch-wheels-rims-PETROL-VENGENCE-5-114-3-19x9-5-FORD-JEEP-MERC-MAZDA-AUDI-/321094544789?pt=AU_Car_Parts_Accessories&hash=item4ac2b9ed95&_uhb=1
My only clearance issue will the the fronts with my r32 gtr brakes I will b e putting on as ill be keeping the rears as standard for now. At worst just decent pads and slotted rotors.
Edited by joshm35
Having a guess by the look at the spokes and the offset, those have no chance of clearing.
Are your brakes on the car yet? If not, you can take them and place them on the backs of wheels ou like to see if they clear.
Varrstoen do some bbs knock offs too, 19x9.5 +22
These are the others I was looking at and I can get them in +25's
http://www.ebay.com.au/itm/19-koya-inox-aston-bmw-audi-merc-holden-ford-euro-5-stud-stainless-lip-/320898242961?pt=AU_Car_Parts_Accessories&hash=item4ab7069991&_uhb=1
No I haven't got the r32 brakes on yet. In transit.
Edited by joshm35
This has probably been covered.. but hey, worth the info..
I wanted a bigger set of brakes on my S1 M35, but without the big $$ price tag.. I need to tow my race car. ( under 1200kgs).
I found the 14mm caliper bolts hard to get a set of 4 spots for. I rang around a few wreckers & found that the R34 GTT calipers had the same bolt size.
The only mod i needed to do, was to remove the existing backing plate. The R34 GTT kit , bolted straight on. Even the GTT brake hoses fitted up.
Great easy mod for $350. I fitted hawk pads from http://www.vsport.com.au/ .. Been to Phillip Island & back with ease..
Hope this helps..
Was that $350 all up less the pads? Or did you buy new discs as well...that sounds super cheap. Any of you guys know a good wrecker to get the r34gtt setup from in Sydney? And also any idea if it would fit under stock Axis 18s? Cheers!
  • 4 weeks later...
Hey Guys,
Firstly, I want to apologize if this has been covered, I've read nearly every single page of this thread and I'm still scratching my head..
A friend of mine rolled his 32 GTR recently. I own a 98 S2 C34 and I wanted to swap the rotors and calipers over for the GTR set up. Does anyone foresee any issues with this? Will I need to get custom brake lines made up for the new Rotors, or should it all interchange relatively simply?
Again, sorry if this has been covered, I wouldn't be posting if I wasn't desperate for an answer.
Thanks in Advance :)
You'd just need spacers made up to go around the bolts
the 32r bolts will have a 12mm diameter, but the c34 hubs have 14mm holes
and maybe trim the backing shield on the rear brakes (no spacers needed there tho) tin snips work well
one of the m35 guys does them, but i've had too many beers to remember exactly who (maybe daleo or jetwreck)
Edited by pipster11
Hey guys need some info... I have recently changed the brake pads in my s2 c34 to the bendix ct pad, since then I have a grinding sound and feel coming from the front brakes at low speeds as well as a squeal like having low pads. I don't really feel it when the brakes are cold but after 15min or so of driving it all starts. Have pulled off the wheels and check the rotors and they are still smooth??????
A couple of things - first have you put a chamfer on the leading edge of the pad? Rubbing it on a sheet of sandpaper e.g. will do.
Also have you replaced the backing plates and applied some copperslip or other anti-squeal compound?
Cheers Tom, much appreciated mate!
What about the lines? Are they interchangeable between the C34 and 32GTR set up?
You can use either, running the stagea lines means you will have to pull the "olive" out of the caliper (its the thing at the bottom of the bolt hole)
lip on the rotor?
did you bed them in? (5-10 really hard stops from 100km/h to 50, then cruise at constant speed for 5 mins, using no brakes during that time)
Scotty makes the spacers for the bolts.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
