Absolutely....just add $200 to the prices :mellow:
Gordon Leven in Emu Plains for the Bridgestone and Yoko Tyres
Gary's motorsport tyres in Eastern Creek for Dunlops
give them a call for exact sizes available.
i got the RA1's and i rate them 1billion% awesome tyre but after around roughly 3-4 laps they feel very unsettled. Only time i get wheelspin is a hard 2nd gear shift...then again my car is fairly stock standard..running 235/45-17's all around so i can rotate them..wear is pretty brutal but they've lasted me a good 4 months now haaaard driving at supersprints and still have plenty in them...
Drunken,
I originally tried the A048's and I found them to be a pretty average tyre. Basically after the first couple of heat cycles they got quite oily almost and the rubber stiffened right up which made them very hard to get heat into them.
The only advantage was it meant the tyres lastest longer but they were a good couple of sec's slower around the track than RE55's.
I know a number of the WRX Club guys are using the Toyo's however. But I still think RE55's are the way to go for the ultimate street tyre. Robo - you need to come to the track again dude!
Have to agree on the 048's, the deterioration in their performance is quite noticeable after a few heat cylces. Most of the guys who run in catagories with choices between 032R's and 048R's are sticking to the 032R's. They are far more consistent in their lap times. Particlualry on the front wheel drive cars, the 048's are only lasting one race meeting on the front. The 032's will do 3 or 4 race meetings.
I have been pushing this with Yokohama for quite some time now and not really getting anywhere. It is good to have another opinion (not fornt wheel drive) to verify against.
:rolleyes: cheers :)
Well that sucks, unless the tyre contract changes Yoko A048R are the tyre of the future for us. We don't want to / can't afford new tyres every round so this will really hurt the lower budget teams :)
Luckily there is an open tender so hopefully we will find a better tyre :(
Well that sucks, unless the tyre contract changes Yoko A048R are the tyre of the future for us.  We don't want to / can't afford new tyres every round so this will really hurt the lower budget teams :D
Luckily there is an open tender so hopefully we will find a better tyre :P
Don't expect the supplier to change as Yokohama are the only ones with a big enough range of sizes to cover all the vehicles. What we need top push for is compound suitability, some sizes are only available in Super Soft which is really a wet weather compound. Some sizxes are only availalbe in Hard, which puts them at a dissadvantage. Start lobbying your delegate now.
:D cheers :D
I have been using Dunlop DZ02G's on my rex and they wear very well on the track and are very consistent. That said you pay $400 a corner for 215/45/17's!! ;)
I'll be putting RE55 265/35/18's on the GT-R for the track, hopefully they will be as consistent.
Regards
Andrew
troy, you have been at work too long. hit shut down and go home mate!! they are taking the mickey... 7:30pm at work is not good.
GTR on street tyres?? what were you thinking :O
RE55s are no good on GTRs at the track, what you really want is a street tyre and really let that ATTESAA thingie work for you...trust me :O
That's the same thing my monkey said when I asked him!! ;)
Andrew
What am i thinking... i cant cheat as well as these GTR fellas. Twin turbos, 4WD, fancy rubber, aftermarket computers with electric toothbrushes ... its my duty as the Minster of Propoganda for lowly GTST owners to try and confuse the enemy
LOL..sheesh, its never good when even on the inernet ppl see me for what i really am :)
What TommO said.
I'd recommend something like a set of Falken Azenis ST115s for a complete n00b. They're not bad as far as streeters go, but there's bugger all grip in them once you press on.
If you want to learn how to drive as quickly as possible (i.e. at the car's limits) you should probably set yourself low limits at first, to see what its like.
The car's easier to bring back since the tyres are more progressive at the limit (and there's less momentum because you're not going as fast), so its good to learn on before trying to get the kind of racing slicks F1 drivers wish they were still allowed to run in qualifying. :)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
