looks tough as nails, still kinda hard to beleive that size tucks in that easy
believe me no1 was as surprised as me, i was expecting to have some decent flare on my guards.. ohh well if ur still not entirely convinved i can take photose of the offset plaque on the inside of the wheel. haha
Skyline model = R32 GTST
Wheel diameter = 17"
Wheel width = 9.5"
Wheel offset = +15
Tyre size = 215/45
Modifications to fit = the fronts are fine and the rears could use a lip on the guard as they scrub a little bit on stock guards
Don't know if anyone is running R34 GTR rims on their 33 GTSt so here goes
Skyline model = R33 GTSt
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +30
Tyre size = 235's all round
Modifications to fit = none (about 1.5º neg camber on the front)
car feels more balanced with same size rims/tires all round... better than the staggered fitments I used to run... and now I can rotate when the rears are worn... food for thought
Thats cool Nick. Any photos?
I'm doing the same with 33 GTR rims but I've gotta get the tiny 215's of em first.
Skyline model = R34 GT-R
Wheel diameter = 19"
Wheel width = 10.5
Wheel offset = +15
Wheels = Nismo LMGT4s
Should i run Tyre size 265/30 or 275/30? I want to lower it so that tyres are on the gaurds without it scrubbing the gaurds and without rolling.
Skyline model = R33 GTS-T
Wheel Brand RAYS VOLK TE37
Wheel width = 9.5"
Wheel offset = +12 on wheels, +25mm spacer front, 30mm spacer rear for ultra wide stance! soo....-13 Front -18 Rear
Tyre size = 255/40/17
Brake rotors = std
Modifications to fit = everything u can think of haha
just went on http://marksink.com/tire_wheel_offset/offset.html .....looks like my new wheels are going to stick out of standard rear guards approx 134mm BAHAHHA! :D
Wheel width = 9.5"
Brake rotors = std
so have u fitted these yet? pics?
  • 4 weeks later...
Anyone know if these with fit a R34GT with standard shocks/springs....
18" CSA Motorvatr's
Bridgestone Potenza 225/40R 18 tyres
Stud pos is 45.
Any idea if i did swap out for adjustable shocks in the near future would I have problems with them hitting at full lock?
Skyline model = R33 GTR
Wheel width = 10"
Wheel offset = -1
Tyre size = 235/40
Modifications to fit = Slight roll the inner lip on the rear guards and stretched tyres to get them to tuck under
Hi guys,
Need some pics of a R33 series 2 GTSt with:
18x9 35 offset
18x10 37 offset
Anyone have this combo on their R33 GTSt?
I just bought some work xd9's in 18x9 +30 and 18x10+37
I did my research and these should fit with only rolled guards.
Unfortunately my computer needed reformatting and i no longer have all the pics i had.
1.
Skyline model = R34 GT/T
Wheel diameter = 17 inch
Wheel width = 8" front 9" rear
Wheel offset = +16
Tyre size = 225/45 front 235/45 rear
2.
Wheel width = 9" all round
Wheel offset = +20
Tyre size = 215/45 front 235/45 rear
coming soon:
3.
Wheel diameter = 18 inch
Wheel width = 9" front 9.5" rear
Wheel offset = +25 front +20 rear
Tyre size = 225/40 front 255/40 rear (still deciding what tyres to use for 18" as ive never had exp with 18" before, is 40 profile ok or would i be better off with 35?)
Modifications to fit = hopefully none.
i rarely see a R34 with nice offset & fitting rims.
Edited by dori32
