im just wondering which of these 2 dump pipes will give you more power - screamer dump pipe or split pulse dump pipe?
Im looking at getting either one which works best for my RB25 Turbocharger im using on my RB20DET engine
Ive seen heaps of companys selling split pulse pipes on EBAY etc but not many selling screamer pipes, anyone know of any companys that sell screamer pipes?
if you want it too sound horridly retarded, get a screamer...
they sound VERY bad on small turbo/pipes IMO.
Heard them on SRs and its pretty p|ssweak compared to a big turbo with an ext gate
If you exhaust is 3" then get the one that plumbs in.
There shouldnt be a performance loss if its 3" to begin with.
Correct. On an internal gated turbo, and a RB25 one at that I would say get the split pulse dump that joins back to the exhaust system. Just get one that seperates the wastegate gasses for a decent length, say 300mm if possible. Not the ones you see that seperate it for 50mm.
A screamer version, which vents it to atmo "might" make a tiny bit more but is ridiculously loud which attracts unwanted attention and is also illegal to boot.
A screamer pipe or "divorved" downpipe will always give you more power.
Whether or not you want a louder exhaust is up to you.
Back to back tests were done on a 7M-GTE (3.0 liter supra turbo) using a full 3" downpipe that replaced that replaced the cast turbo elbow and all, vs. a full 3" downpipe with a divorced wastegate or screamer pipe as you call it.
The result was a gain of 22 wheel horsepower from just the screamer pipe. This was done on a bone stock motor with only a cat back and an air filter + the 2 aforementioned downpipes.
Pretty big difference if you ask me.
you'll only have a gain if the exhaust is restrictive enough that you loose power.
There are a few cars the come to mind that have been tested with/without the atmo gate (on bigger cars) and there is no loss.
mind you this is using 4" exhausts and stuff. But for a small turbo setup that obviously flows a lot less... should b arite
  • 1 month later...
screamer pipes are somewhat illegal, anyonet hat thinks that this noise is tops, well drive ur car to a racetrack or drag strip. Put it on, and go for a hoon, then take it off again and drive home. On a street car i beleive it is a stupid idea. :D
have a nice legal streetable car. be it mostly legal. hehe
peace out, yeahhhhhhhhhhhhhhhh
My guess is the difference will be bugger all compared to a split dump pipe, not a open dump like you suggested.
For example, A CES dump pipe. That would have been a much better comparison.
i beg to differ.
My car is a daily driver and i have a screamer on my Rb20 and dont have any problems or a rep as being a hooooon.
Its all in the way you use the right foot if you ask me as i have heard some cars down here (turbo's, V8's) that are louder than my screamer pipe :D
Beauty of living somewhere like the Apple Isle where they are pretty easy going on mods and no EPA here at the mo either :(
Cheers B
  • 7 years later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
