  • Replies 714
Posted Images
Sk, Pm'd you at lunch time today...
Response sent.
Till the gallery is back and linked, following are the prices for the full kit;
Nissan Skyline
R33GTST
73175 Front Springs $144.00
83139 Rear Springs $144.00
Front Bilstein Shocks $476.00
Rear Bilstein Shocks $476.00
BNF24Z Front adj stabiliser bar $219.00
BNR11XZ Rear adj stabiliser bar $219.00
KCA331 Caster Kit $110.00
KCA348 Front Camber kit $272.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
W0921 Bump Stop & Dust Cover X 2 $102.00
Freight Zero
Sub Total $2,390.00
Less extra 5% $119.50
Total $2,270.50
:( cheers :rant:
Hey im interested in shocks alone, can you PM me with details. Im ready to buy any time if you have stock.
Interested in front and rear.
I just wondering if I should do anything else at the same time. I currently have some too low and too hard springs that came in it off the boat. I really hate them, but I dont know if that is more to do with the shocks in combination with the springs.
Am I correct in reading this will give me some height adjustability, I just think it could do with being another inch higher purely for reasons of functionality and im also sure its too low to handle well.
I havent changed shocks in a skyline before, but played around with enough other cars, so it shouldnt be a huge deal I assume? Doesnt seem to be anyone trust worthy around here.
PM sent.
:ermm: cheers :)
Have just installed the bilstein kit from this group buy.
l actually look forward to getting into my car for once, as opposed to dreading the harsh ride before this awesome setup.
Garry how do you remain so patient ansewring the same questions over and over again?? ( i know i'm guilty of it :D )
All i have to say is that l am another happy customer.
Cheers Garry Thanks for everything. look forward to buying the stabilser's soon.
Garry how do you remain so patient ansewring the same questions over and over again?? ( i know i'm guilty of it :P )
What did you have installed Optimus and on what car ?
He bought springs, shocks, caster kit and a bump stop/dust cover kit for his R33GTST.
He is saving up to buy the stabiliser bars
:) cheers :ermm:
Edited by Sydneykid
The front caster kit is a must thave, you won't believe how much a few extra degrees of caster improves the handling
Now i dont know much about suspension work, but my bushes have worn out (cracked), and its affecting my handling a bit even after wheel alignment.
Btw your pictures dont seem to work, so anychance you can fix this also please :)
Now, i got quoted at a suspension shop to fix the following:
S+F Adj Mod Rad Bush
Adj Cam Bushes
Plus wheel alignment- $610bucks.
Now i know this will replace my bushes and fix my front camber, as i think it was in negatives. Front camber should be dailed in postive to get more Go-kart response right??
Anyways what im askin is, what does your front caster kit include?? Or is this totally different??
Sorry if im askin stupid questions..
So in the near future i would like to fix these things.. AS going over 100ks the car turns left. It was ok for a few days after W/A, but now back to normal.
CHeers SK!! :ermm:
Edited by siddr20
Adj Cam Bushes
CHeers SK!! :D
The pictures don't work at the moment due to the gallery upgrade, Prank is working on that.
The caster kit enables the caster to be adjusted. Caster is the change in camber when you turn the steering wheel. Positive caster is where the outside wheel (in the turn) goes negative camber and the inside wheel goes positive camber. Skylines NEVER have enough caster, that's why they wander at speed, are reluctant to turn in and have poor steering feel. Hence the need for adjustable caster (radius rod) bushes.
The front camber kit enables adjustement of the static camber. Camber is used to keep the maimum contact pathc of the tyre to the road surface. So you need negative camber on the outside wheel (in the turn) when the chassis rolls. You don't need negative camber on the inside wheel though.
This why caster is better than camber, camber is always there even when you don't need it. Caster is only there when you do need it ie; when you turn the steering wheel.
:) cheers :P
Thanks for the helpful and informative reply SK. Learnt a lot.
Maybe if this group buy still goes till end of year, i might buy some shocks and springs of you..
I remember reading somewhere in this thread about how low the springs are set at. But now i cant seem to find it?? Think im going blind.
Atm, my fronts are 355mm, and rears are 370mm. (from centre of wheels to wheel arch)
Maybe with these shocks and springs, i can go a little lower? Hopefully the rear atleast??
Sorry i cant find your reply, where you wrote about the ride height..
Sorry the heights are included in the pisture which is not linked at the moment due to the gallery upgrade. Prank is working on fixing that.
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. There are 6 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that Skylines handle best around 355 mm front and 345 mm rear (centre of wheel to guard).
The standard circlip groove with the Whiteline springs gives ~355 mm front and ~345 mm rear. So the range of heights is ~370 mm to ~320 mm on the front and ~360 to ~310 mm on the rear.
:laugh: cheers :D
SK i PM'd you but understand u may not of got it, i am after some suspension bits which i need to purchase this week have the money ready to go when u have the bits, its all in the PM, can you reply when you get a chance thanks
adam
Hi,
Im interested in a Camber kit, can you please PM me some details of this and pricing including del to Perth :)
Thanks.
PM sent
:ermm: cheers :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
