  • Replies 517
my pictures don't look anywhere near as good as everybody else's on here :rolleyes:
these are pictures of my old car (2003 Nissan Sentra SE-R Spec V) before i got my 33
I'm using the Sony Cybershot DSC-T1 camera w/o any tripod. this is my first digital camera and i'm still learning every time i go out and take pictures :rolleyes:
this is the top of the steps of the Philadelphia Art Museum (think the movie Rocky :unsure: )
the Philadelphia skyline on a very overcast evening
on the far left in the back of the picture, that short building with the statue on the top.....that's City Hall and the statue on the top is William Penn (founder of Pennsylvania)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
