ive had a search around and cant find anyone else with a problem that seems as bad as mine,
thats why im posting,
the 1st problem is under acceleration the rear end feels as if every bolt in the rear cradle is loose and the whole thing is just swaying about to do as it pleases very unseltling feeling,
but whats worse is under hard braking the whole car pulls very savagely to the right, requiring you to make sure yourve got a firm grip on the wheel incredable unselting
now ive checked everything from all the plug and loom conections, pwr steer fluid level/leaks, even the rear rack to make sure it was secure
so im stumped as to what it could be, so if anyone can help, please
(sorry bout the rave)
https://www.sau.com.au/forums/topic/86285-hicas-big-problem/
Can I suggest that the brake problem is unrelated to the rear end problem. The brake problem is probably the result of the LH caliper siezing, sometimes it can be an imbalance in the front caster settings.
Its denfinitely not a problem with bushes as it has nolathane bushes fittted through out front an rear,
and i can tell the difference between the the two it is the hicas, badly worn bushes never feel like this
its not an alignment issue either as i just got new tyres fitted and a alignment done,
but the hicas warning light is on most off time to
and the car is fitted with an aftermarket steer wheel to
That would have been useful info to have from the start :)
Is the wheel a proper HICAS wheel? Is it aligned correctly?
There should be a slot in the back of the wheel for a long black protusion in the centre of the wheel to insert into.
Also what the elk says sounds like a good opinion too.
Did the subframe bushes get done as well??? if not they are the culprit I'm talking about.
There are two different boss kits for R32 (unsure of which model you have). Part numbers ON-110 and ON-115 (iirc) and one is used for early model R32's and one for late models.
Search for a thread titled "My GTR" by "Pentae" and there is a lot of info on the second page. Might help clarify? If not R32, disregard! :D
hi, did they do the bushes in the hubs also and the rear rack ends/tierods, if these are worn this will add a lot of wiggle to the rear end, jack up rear of car, support on stands and try to turn the rear wheels left to right by hand, there should be no movement at all!
but more likely it will be your steering wheel, aftermarket wheels seem to cause a few probs with hicas as people dont align the pin properly.
DON'T get your wheels aligned at Bob Janes or Tyre Power etc (just a warning!)...Bob funked my HICAS, the light is on when cold and on when I turn left now :cheers:
Brakes: check the pads...also the distance away from the disc of the front left pad might be greater than the front right....possibly due to being more warn down.
HICAS: meh!, everybody dance now (Baseketball happy dance :D )
  • 5 years later...
Hmmm i have a momo wheel aswell i dunno what boss hit it have either i thinks its also momo so i dunno if my hicas is stuffing up i never see light on only when i start the car and then it switches off but i am also getting a scraping when i 1st start out driving the car when cold and a lump lump lump like i am running over golf balls but only with right hand rear wheel i check tyre seems good and when i get abit of speed it seems to go away and i dont feel it till i leave my car and start it again after work.
That sounds far to dangerous to waste money on fixing
Just get a HICAS lock bar. I spent forever trying to avoid doing this cause I had perfectly working HICAS, but it started making the car feel a bit unsteady in the wet so I got rid of it.
HICAS Lock Bar, Wheel Alignment and should be sweet
I have this same problem only the lump sound is on the front passenger side. The car still handles wonderfully, just that sound worries me. I'll probably take a look later in the week when I install my brake pads.
Doesn't sound like a HICAS problem to me, HYBRID VL - especially if the HICAS light isn't coming/staying on
Go see a wheel/suspension place and get stuff checked out. Could be anything like worn suspension bushes - best to get it checked out.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
