Clutch is in. Its a heavy duty full organic face clutch. Grabby, and bites well.
Still waiting for the injectors.... Nengun keeps putting the despatch date back.. :P This sucks. And also hopefull the datalogic group buy goes well too. NOt sure how long it will take to have that delivered. Will make the tuners job so much easier.
  • Replies 333
how long ago did you order? i paid for mine 2 weeks ago nearly and i got a email today that the order is complete and items being shipped. that was for 12 740's nismo.
Did you get that email too? i cant get acces to the site ? is it down for u too?
no email saying they have been shipped yet, and 5-6 weeks is rediculous. Maybe I should have got them from Greenline, as apparently they are really quick. Then again, I';ve had stuff from nengun only take 4 days..
N1 oil pump - 2 weeks
Powerfc - 5 weeks
Camgear - 4 days
Not to stray off topic too much, but I think it basically depends on availability. Cam gears are cheap and popular, so I would expect a supplier to hold quiet a bit of stock. More expensive and unique items, I wouldn't, because who knows how long they would have to sit on them before sale.
For the record I ordered some Greddy Front Extension Pipes through Nengun. It took just over 8 weeks for the order to be sent from Japan, and three weeks to clear customs. All up, almost exactly 3 months. I was in no rush, and Nengun kept me informed (delay was due to JP holidays and Greddy having to actually make the item), thankfully :D
ohh baby. trust dumps. have you fitted them yet lucien? if not can i come and fondle them at some point before you put them on? I'm really keen so see some in person.
  • 1 month later...
damn.... I just got my car back...
On 95ron fuel and 14psi, with this setup, I made 223rwkw and 450nm or torque...
This really sucks... If so pissed off!
Does anyone have any ideas why so low??
The stock turbo made 210rwkw and 420nm or torque at 12psi!
Edited by The Mafia
Mods To date -
600x300x75 FMIC
Garret GT30r with a 0.63 rear standard manifold
Full partitioned 4 inch intake, with a VH45 AFM (90mm)
Full exhaust - split dump, and 3 - 3.5 - 4 inch exhaust with a HiFlow cat
Walbro 250l Fuel pump
Nismo 550cc injectors
PowerFC and Datalogit
The best fuel we have here is 95ron...yeah I know, it sucks. Mackay is a shit place for that sort of thing.
Edited by The Mafia
The stock turbine A/R of the RB25DET is 0.63. The GTR's have the 0.42.
I am almost 100% sure that the VG30DETT turbine A/R is 0.63 also but I will have to confirm tomorrow.
Edited by 3lit3 32
Next tank I will fill up with 95RON and see how much ign. I need to pull out.
Going from BP98 to BP ULP 91 I had to pull out 7 degree's in 4th to stop ping.
Mafia, you are running the GT3076R .6comp cover? or?
Edited by Cubes
Cubes - Its a VG30 ex housing, and a .7 comp cover
Miller - Clutch is 3100 pounds..Definately not the clutch
Don't need a pressure regulator, rail pressure was fine
Got cam gears, didn't make a difference..
you're saying 5-7rwks... dude, I remember someone posting with the same setup pulling 250 - 260 rwkw... I don't understand why mine is reading so low..
James how do you know this... lol Wipe your chin. :D
Mafia, so you don't know the gt30 specs? There's 3 basically... GT3071R, GT3076R, GT3040R.
You are right.. there was only really 1 person that made 270rwkw with the same setup, there was that one bloke with the horsepowerinabox turbo that made 260rwkw with 20psi on a rb25 turbine housing.
Then there's Bass Junky that made 250rwkw with 14psi and 260pon cams, and now there you with roughly the same power also, well considering your running crap 95ron.
hrmmm.. Makes me wonder if these ppls who have cracked 260-270rwkw's have either ran an aftermarket exh. manifolds or possibly even dropped the static comp ratio so they can push some decent boost in to it. Bass Junky's wouldn't take any more than 14psi.. ping. :(
Edited by Cubes
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
