Clutch is in. Its a heavy duty full organic face clutch. Grabby, and bites well.
Still waiting for the injectors.... Nengun keeps putting the despatch date back.. :P This sucks. And also hopefull the datalogic group buy goes well too. NOt sure how long it will take to have that delivered. Will make the tuners job so much easier.
  • Replies 333
how long ago did you order? i paid for mine 2 weeks ago nearly and i got a email today that the order is complete and items being shipped. that was for 12 740's nismo.
Did you get that email too? i cant get acces to the site ? is it down for u too?
no email saying they have been shipped yet, and 5-6 weeks is rediculous. Maybe I should have got them from Greenline, as apparently they are really quick. Then again, I';ve had stuff from nengun only take 4 days..
N1 oil pump - 2 weeks
Powerfc - 5 weeks
Camgear - 4 days
Not to stray off topic too much, but I think it basically depends on availability. Cam gears are cheap and popular, so I would expect a supplier to hold quiet a bit of stock. More expensive and unique items, I wouldn't, because who knows how long they would have to sit on them before sale.
For the record I ordered some Greddy Front Extension Pipes through Nengun. It took just over 8 weeks for the order to be sent from Japan, and three weeks to clear customs. All up, almost exactly 3 months. I was in no rush, and Nengun kept me informed (delay was due to JP holidays and Greddy having to actually make the item), thankfully :D
ohh baby. trust dumps. have you fitted them yet lucien? if not can i come and fondle them at some point before you put them on? I'm really keen so see some in person.
  • 1 month later...
damn.... I just got my car back...
On 95ron fuel and 14psi, with this setup, I made 223rwkw and 450nm or torque...
This really sucks... If so pissed off!
Does anyone have any ideas why so low??
The stock turbo made 210rwkw and 420nm or torque at 12psi!
Edited by The Mafia
Mods To date -
600x300x75 FMIC
Garret GT30r with a 0.63 rear standard manifold
Full partitioned 4 inch intake, with a VH45 AFM (90mm)
Full exhaust - split dump, and 3 - 3.5 - 4 inch exhaust with a HiFlow cat
Walbro 250l Fuel pump
Nismo 550cc injectors
PowerFC and Datalogit
The best fuel we have here is 95ron...yeah I know, it sucks. Mackay is a shit place for that sort of thing.
Edited by The Mafia
The stock turbine A/R of the RB25DET is 0.63. The GTR's have the 0.42.
I am almost 100% sure that the VG30DETT turbine A/R is 0.63 also but I will have to confirm tomorrow.
Edited by 3lit3 32
Next tank I will fill up with 95RON and see how much ign. I need to pull out.
Going from BP98 to BP ULP 91 I had to pull out 7 degree's in 4th to stop ping.
Mafia, you are running the GT3076R .6comp cover? or?
Edited by Cubes
Cubes - Its a VG30 ex housing, and a .7 comp cover
Miller - Clutch is 3100 pounds..Definately not the clutch
Don't need a pressure regulator, rail pressure was fine
Got cam gears, didn't make a difference..
you're saying 5-7rwks... dude, I remember someone posting with the same setup pulling 250 - 260 rwkw... I don't understand why mine is reading so low..
James how do you know this... lol Wipe your chin. :D
Mafia, so you don't know the gt30 specs? There's 3 basically... GT3071R, GT3076R, GT3040R.
You are right.. there was only really 1 person that made 270rwkw with the same setup, there was that one bloke with the horsepowerinabox turbo that made 260rwkw with 20psi on a rb25 turbine housing.
Then there's Bass Junky that made 250rwkw with 14psi and 260pon cams, and now there you with roughly the same power also, well considering your running crap 95ron.
hrmmm.. Makes me wonder if these ppls who have cracked 260-270rwkw's have either ran an aftermarket exh. manifolds or possibly even dropped the static comp ratio so they can push some decent boost in to it. Bass Junky's wouldn't take any more than 14psi.. ping. :(
Edited by Cubes
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
