You and me both.  Its bizarre that a couple of grand on new turbos suddenly seems like "cheap" insurance :P
Consider that some unlucky buggers are paying a couple of grand insurance each year..........glad it's not me AND the turbos are rebuilt.
  • Replies 61
Posted Images
yes, i guessed it's probably just HKS actuators on stock turbos.
Jerry, i was joking about hitting them with a hammer to check if they are steel or not! :D
I know , of course you are not going to hammer them !
haha, you have never seen me work on a car then! :D it was quite a reasonable assumption to make. If it can't be hammered it can't be fixed. this rule goes for electronics too.
Lucien: it's not so much the 3 grand to buy the turbos, it's that if i buy them i will not bother putting stock dumps back on, so that will be another grand, then i will be past the limit of the injectors (already pretty maxed with the current 253rwkw), plus the fuel pump, there is another grand, will also want to go cams while i'm at it, there's another grand. And to be honest i'm quite happy with the way the car is now. very responsive, it goes hard enough for now. once i am cutting some really fast lap times then i will do all the above in one hit :)
it would take some hard physics and experiments to prove it though I would say..
Actually would probably take me about an hour (less) with a sample of the 'dust' and the remains of the wheel - but note I'm not offering to do it, I really don't have the time, plus I'm a born sceptic :D
Lucien: it's not so much the 3 grand to buy the turbos, it's that if i buy them i will not bother putting stock dumps back on, so that will be another grand, then i will be past the limit of the injectors (already pretty maxed with the current 253rwkw), plus the fuel pump, there is another grand, will also want to go cams while i'm at it, there's another grand. And to be honest i'm quite happy with the way the car is now. very responsive, it goes hard enough for now. once i am cutting some really fast lap times then i will do all the above in one hit :D
Yes, I agree... I'm already heading down this path. New dump/front already ordered, PFC ordered, bigger exhaust ordered, will have to get cam gears (would prefer poncams + gears, but $$$), probably end up with new turbos shortly. Its a bit of a trap. Still, I figure if you get small enough replacement turbos you can still have them near their effeciency range whilst only getting 250-odd rwkw but still have headroom. That way you can keep the stock fuel system (and cams), not have a laggy ho, and when funds allow additional upgrades get a nice extra kick.
At least the rest of the stock parts aren't a ticking time bomb.
I have the same sleeping problems with my stock turbos. Cheap insurance would be a set of garrett turbos but i'm not going to be happy with those. So HKS turbos it is at $4k + $1.3k dump pipes + injectors + fuel pump + ECU + other bits and pieces. It doesnt stop!
I mean to trace what actually happens in the "explosion" of the exhaust wheel :blink:
One reason some engine are not damaged might be the fact that sometimes the wheel just drops off.. and sits in the exhaust, while others have almost nothing left.
yeah, for me 250-260 rwkw is as far as i want to go on stock injectors and AFMs. at 253 rwkw my injectors occasionaly hit the magic 100 briefly. but my PFC is tuned quite rich at high rpm for a little extra safety, so with an AFR closer to say 12:1 you could get to 260rwkw and still be just into the 90s duty cycle wise.
I definately think if you are doing the turbos (no matter which ones) it's worth doing the injectors and pump and possibly afms too.
  • 4 months later...
Lucky I found this thread again (after 4 months)...see, I know how to use the search button :)
Anyway, I have a PFC and EBC coming soon and with the R34 turbos boosted to 1bar (0.7bar at the moment), is that suitable for a track day or a few quarter mile runs? Seen as though 1bar is the max that everyone is saying to boost them too I am a little paranoid about them blowing up....
I have plans to get some steel wheel bolt on replacement turbos later on but not for a few years after this PFC tune next month.
If a D-Jetro is tuned right with the boost set at 1bar, what sort of power will I expect? 250-260kW? and is it worth getting it set at 0.9bar instead?
cheers
it's hard to predict mate if they will be ok or not. if you really want to be safe you need to get some steel wheels in there. if you can take the stress, just run them at 1 bar and see how it goes.
i run 1.4 on my turbos, i dont have a clue what they are. but they f**king love it
If you have alook down the back of the AFM's on the exhaust side of the engine you can see the front turbo, I could see Garrett and an A/R rating on mine maybe you could have a look see?
Guest Mashrock
the car isnt with me at the moment but there is a garrett from memory and then a blank raised up bit. where it looks like something should be..
but from what i get from a very cluttered auction sheet is
N1 turbo
N1 piston
Edited by Mashrock
  • 1 year later...
I have had a read of the thread and i still have a couple of questions, which is are R34 gtr turbos steel or ceramic and how can you check if they are?
Serial numbers?
The reason I ask is because someone is selling them and has told me that they have a steel exhaust wheel.
Also is there a point in buying r34 stock gtr turbos to replace stock r32 ones?
Cheers
still to date i havent found out if the are steel or ceramic!!
yeah they are ball bearing, i am running 14psi thro mine, keeping it safe as i was told the did have steel wheels on, from a scratch test but i stiull wanna be safe. my car is making 321rwhp or 239.8rwkw's with 14psi. and a slipping clutch haha!
good luck and i hope this helps
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
