Went to GL Pro Sound in Essendon yesterday and got quoted $650 for a Mongoose M80 Alarm supplied and fitted. I'll need to install the turbo timer (which I'm eagerly awaiting for from eBay) then I will book a time with GL Pro Sound to install
you reckon that's a good price??
G`DAY BDJ SEEM`S A BIT DEAR I HAD UP GRADE SO I KEPT STANDARD KEYLESS ENTERY,AS I DIDN`T WANT ANY OTHER SIT ON MY KEY,I PAID $350,CUSTODIAN AS100,HAVE HAD NO WORRIES SO FAR,WITH REGARD TO TURBO TIMER DO YOU NEED ONE JUST LET CAR SIT FOR 20SECOND`S & OFF YOU GO.+ JUST SOMETHING TO FU-KUP SO SAVE YOUR SELF SOME MONEY.
GOOL LUCK WITH YOUR NEW RIDE ENJOY,CHEER`S CHUCKIE.
  • Replies 43
Well I got my M80 Installed. Alarm is pretty good. But I'm going to take it back to GL Pro Sound. For some reason when i went for a longish drive (went for a drive with a mate to Frankston and then turned around and went back home). I stopped at a maccas for a stretch and to get something to drink. My GReddy turbo timer was on auto and was up to 9 minutes. No probs turn "off" the ignition, let the turbo timer do its business and arm the alarm. Approx 1 minute after arming the alarm has gone off!! had to disarm and then wait about 2 minutes or so and re-arm. I got back home where it was more quiet and can try to diag the problem. TT was auto set to 2 and a half minutes. got out and arm the alarm. was having a ciggy and I hear what I think is the fuel pump priming or something and then the alarm went off. disarm and rearm and didn't do it again.
Anyone had this same issue (does that mean the fuel pump is on its way out or would that be cause the alarm to go off because it thinks someone is trying to start the motor)
One of my mates dad's does alarm/imob installs for a living so I got a sweet mates rates + beer payment deal :)
I've got a Mongoose system, don't know the model probably the M80 with glass break sensor and window lift kit.
I wasn't sure whether the window lift kit was worth the extra at the time, but I love it! So easy, just close the door walk away and blip its all taken care of.
how are you setting the alarm? car on , timing down - PRESS 1 and HOLD or press 1?
answer that question first and I'll help you with it.
I have been doing it like this
1. car is running (of course)
2. turn off, turbo timer is on and counting down
3. I'm pressing 1 (just press 1 not press 1 and hold)
You have to excuse me if i have been doing something wrong (first time owner of a turbo car).
press and HOLD 1 with the car running on timer, it will chirp, diasble the sensors but still look at the doors and if one is opened it will shut the car down and sound the alarm.
once the car times out it will chirp again and bring the sensors online.
make sure it works on ALL doors. I have seen too many of them that only trigger on the drivers door.
if it DOES NOT chirp when you do the above they DID NOT turn the function on. if you have the book enable option 13. you will need to TOTALLY disconnect the timer for this to work.
let me know how you go.
I tried it last night...didn't work..do you want me to disable the impact sensor (by pressing 1 then 2)...Although when i was trying just normally, it went off again...the alarm was was going off but the motor was still running. check on the led light what triggered it off - it said that the impact sensor was triggered...I'll keep trying
I have a gsm paging alarm in mine which i think is more useful than those pagers where you have to be standing next to the car...can also arm or disarm via gsm. Just need a prepaid sim card to run it
Got links to this system, Sir Duncan?
nah ring me in the morn. details in sig. they didnt do it right.
Hey Chris, all fixed. the silly buggers did not have the turbo timer function turned on so they did and turned down the shock senor as well. It's at a good level but not so sensitive that the car is going to trigger the alarm while the TT is counting down
thats exactly the problem you described to me. so it works as I stated now?
duncan, PM pls.
  • 9 months later...
Hi guys,
digging up an old thread; I need to find somewhere in Adelaide to install a Mongoose M80G in my stagea, someone who has at least worked on imports... does anyone know of a good place in Adelaide who has worked on imports? I have seen some dodgy alarm installs... I'll be pulling as much off as I can to make it easier for them... but yeah don't want anyone making a mess of my wiring.
Thanks
DaveB
  • 5 years later...
This thread is old but I will post with a question my problem.
S1 Stagea with a Mongoose M60 alarm. When it was installed something like 6 years ago the installer didn't/couldn't work out how to install it with the decaying interior lights. So when I close the door I have to wait the 30sec or so before alarming otherwise I get the "your door is open" chirps... which is fine just annoying but as I don't drive the car much I havn't bothered to fix it.
Can someone tell me how to fix it or do I need a "profesional" installer? I'm in Brisbane Samford area.
Hi guys im having trouble with my car alarm. When leaving the car and turn alarm on the doors no longer lock automatically. And sam thing on returning to car not unlocking. Very frustrating. ..... is a steelmatre alarm is it worth trying to fix .. or should I replace with a better system .... any help you could give me would be appreciated.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
