General consensus for a long time has been that BP Ultimate was the best 98 RON fuel in Asutralia. Guess again - BP Ultimate gave the least power:
Results were:
Ethanol 98 > Vortex 98 > Mobil Synergy 8000 > Optimax > BP Ultimate
Click here for the full report
interesting stuff, i grabbed it from OCAU thought you guys might like to know :)
Edited by CEF11E
https://www.sau.com.au/forums/topic/90947-98-ron-fuels-tested-with-results/
  • Replies 62
Posted Images
Very intresting indeed.
Does anyone know the effect of using 10% Ethanol 98 Ron fuel in turbocharged 'high performance' motors over a long period of time?
Edit: Vortex in Sth Aus is 95 ron, and Optimax doesnt exist (as far as I am aware) - premium fuels like Caltex, Liberty, Woolworths, and Shell are all 95-96ron here in Adelaide.
Brendan :)
Edited by bwilkeson
not sure ofver years but running tolulene and Ethanol has been common practice in racing for many years.
not sure how this effects the longevity of a road going cars engine though.
Its better for the environment to use ethanol so i am going to give it a go.
The Vortex 98 we get in Sydney (from Kurnell) is very rich in Toluene...you can smell it!
No. sorry to say Vortex 95 and 98 are not rich in Toluene.Toluene is a solvent . Different refineries use different processes to increase RON . I make the stuff at kurnell. Also the Companies have agreements in different states about supply. There is no Caltex refinery in Victoria. You will probably find that is a Shell product.
Hmmmm......an interesting report.
One comment that I have is that BP Ultimate is only produced in Perth. All the other "bulk samples" (i.e. from retail petrol stations) are produced on the East Coast.
It is reasonable to expect that of all the bulk samples tested , BP Ultimate would be the most aged as has been transported from Perth. t is also more likely to have undergone addditional handlng and therefore there is a possibility of increased loss of volatiles. The report acknowledges that age has an effect on the quality of the fuel.
I'm not saying that the results would be different had a newer (fresher?)BP sample been used, but it is certainly a consideration.
KIMBOD so your saying fuels ant fuels meaning the product you might get in one state could be a bit differnet from the same produst sold in a different state.
pete
pete
I'm just leaving for work I will give you a better reply later.RememberWA has one BP refinery. SA now has no refinery as MOBIL shut their refinery, VIC has SHELL Geelong and MOBIL Altona, NSW CALTEX Kurnell and SHELL Clyde and QLD has CALTEX Lytton and BP Bulwa Island. Each product can change state to state as different companies use differing process's and technoligies to increase RON .
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
