blew my gearbox saturday :) (in the cefiro), now i gotta find another asap :woot:
You have to be softer on your changes young man :D
UPDATE: I still have to pull the motor out of the 32 :) so i haven't really progressed any further than last time :(
Having no wheels and no money bites the big one :)
Well an update for me, hole in one of the welsh plugs in the Apollo and it needs a hose kit. Cause i dont have the $700 they want to fix it im now officially car less and thats 4 cars in the drive now that done work :huh:
ROCK BOTTOM meh...
well i pulled my diff out to take the shim that i had put in out because it was to tight. im mate got a bit hasty putting it back to gether and started hitting things with a hammer and ended up braking a sir clip on one of the half shafts. oh thats righ i go a new clip from nissan whent to fix it and hed broken the other on to. so another day waiting for parts. dam it.
Well an update for me, hole in one of the welsh plugs in the Apollo and it needs a hose kit. Cause i dont have the $700 they want to fix it im now officially car less and thats 4 cars in the drive now that done work :)
ROCK BOTTOM meh...
Chin up Ben, things will get better.
update for me,
Car goes back on the rollers will dr drift is over. Not sure if mine gets done tomorrow or monday.
Would of liked to be off on sunday for the dyno comp, but i'm day shift.
Edited by woolls
Cheers mate, pretty happy considering it only has minimal engine mods and a tired old motor! I guess she still has a little life in her yet :wave:
Mods: (RB20DET) FMIC, Bosch 040, Gizmo EBC (14.5psi), 3"Ex + Dump, Pod and an R34 Neo Turbo
dam thats good so you didnt need injectors??? im gessing the stockies would be getting pretty maxed. did dr drift tune it for you? oh nad thats a fair bit of boost i thought you could only run like 12 throught thoes neo turbos. whats it feel like toddy i wish i could go for a ride id like to know what near 200 in a 32 was like.
cheers guys... yeah, pretty happy with it! goes very well, I think it has been tuned a little more for top end as it has a bit more lag but still not too bad due to the turbo.
14psi is fine on the turbo, wouldn't go anymore but it should be fine. This one has steel wheels and holds strong!
Update for my car. I' ve finished pulling off the old intake manifold and turbo manifold and have drained al the coolant out of my block. somehow managed to get coolant down throu the valves. luck the rings were in good condition because i didn't get much fluid in the oil at all. should be all up and running by the end of the week
Well im stuck in 2mind sets at the moment with what i want to do with the 32. First thing first is to pull the motor out and strip it down to see what the damage is and go from there :ninja:
Part of me just wants to get rid of it and be done with it for a while as there will always be time for more cars/toys.
The other half wants me to rebuild it better than before, fit the parts i have and see how much potential it really has :(
205rwks with a turbo, FMIC and dump on 14psi mmmmmmmmmmmmmmmm imagine what it could do with forgies, cams, cam gears and 21psi :happy:
Update for me, got a few bits to try and make me look better at the drift day next weekend :(
Hicas lockbar
D-project tie rods
D-project castor rods
D-project subframe bushes
D-project tie rod ends
D-project lower arm brace
looking forward to seeing how much difference not having HICAS makes
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
