Yeah I have seen URAS NS01 17" they look alright to, if you could shoot me a pm on a price would be great thanks :thumbsup:
And I know of a guy that run 6pot Alcons with 365mm rotors with R34 GTR rims so the clearance on the URAS NS01 17" must be awesome, and do you now how much a URAS rims weighs?
Cheers
Cheers
Checking on the weight mate, will PM you tomorrow. Matt sounds keen on some too!
The Whites ran 365s with their White Hot 8 piston calipers under R34 rims also.
Put my wheels back on and the front bar. needs to be repaired again though. Haven't done much to the car for a bit. changed some of the vacum hoses over to nice shiney blue silicon ones i got today as well.
that reminds me, i better buy a window net and isolation switch for mine before i get it log booked
My advice for you fellas that are buying cutout switches,is to buy the ones that have the auxilary contact block, so when you operate the battery isolator you also cut the ignition as well as ground the ignition circuit through a resistor, which will minimise the risk of a voltage spike causing any damage.
Exhaust is done, still sounds loud but is quiet inside the car compaired to having it dumped behind front wheel. :P
Now need to get it tuned again and change the cam timing to get some more mid range.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
