anyone know if boost in lton does nistunes yet?
i've heard that brad likes to push the use of microtech and i've been told by some guys in the know that there are much better options
i find that if you do mods yourself you know when stuff isn't quite right and you can usually pinpoint it more easily
hmmm, might have to pay him a visit then......
i thought gt garage in hobart were the main nistuners in tas and a few ppl from lton go down there for nistuning
people go every where over tas to get stuff done because of one reason or another.
all you have to do is ask. ive been dealing with brad for years now and i didnt even know he dealt with nistune untill a few months ago. i guess you never know unless you ask.
brad has had a lot of experiance tuning all kinds of ecus. he profers Haltechs much like fueltech like vipecs. every place has there profered.
at then end of the day the ecu is there to adjust parameters of the engine and how effiently it does this is all that matters. Ecus like wolf and microtech have half as many load points to adjust these that is why they are not viewed to be as good. plenty of people still use them thoe.
might go talk to him if i decide to srop some money on the stagea
when would i be able to try out those d1r's?
when ever you like. just send me a pm and arange a time. they are on my race car and only 5 mins to pull off.
ive also found boost to be cheaper than GT for general tunes and nistunes.
Huge thanks to Damo yet again. Managed to get my speedo working and repair a snapped wire on one of my knock sensors.
Possibly was dodgy connection prior to me snapping wire as I now a full power with no pops/bangs/misfires whatsoever and I now have a working speedo :rofl:
Now touch wood nothing will go wrong so I make the track day in August.
so after talking to the original owner of my 33 im even more interetsed to see what sort of power it has now, turns out that before the engine was rebuilt with 26 goodies it made 207.3rwkw on 12psi & 228rwkw on 15psi
Edited by Autumn33
pulled off the rear bar of the 33 today to see how bad the damage is ( was done by the previous ownerspank.gif )
so the 33 currently looks like this sad.gif ( the skyline center garnish is just sitting there so it looks more in on one side)
Edited by Autumn33
little update been talking about ecus a bit lookn at a haltec platnum or the link thats a direct plug in with the r34 true they where going to look into it for me depends on $$ for wat i get in the end ...
on a diff note got my rocker covers back thanx to L'ton powder coating shit pics (Fn ipod cam) but will look grate on ,get my plenum and pipes back 2mora
ill add pics as i get them IMG_0152.jpg?t=1308124405(space blue) to go with my other parts :thumbsup:
how much was that if you don't mind me asking?
also, i'd go see brad at boost for a nistune
pretty sure they will support up to about 500hp (don't know exactly) but it will support bigger injectors, bigger afm, and lots of stuff (plus they keep being able to unlock more and more features with every new firmware update)
Send Veeto a PM, he just put a Nistune in his Stagea, pretty cheaply too.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
