Well I've got the day off, and I'm making up my wing stands and have measured out my custom 'jack's backyard aerodynamics' wing ends.
360mm stands to get the sucker at basic roof line. The wing blade is a carbon jobbie with a sorta built in gurney flap, so, hope it works as well as looks.
and my dual wing blade/ends should be pretty unique, should have it close by the end of the weekend.
my ass dyno/aero effects-o-metre is light years ahead of that shit.
i'll test it by running with it at the track, then unbolt it and run with no wing and see how it compares.
I'm tipping around a 10-15k loss of speed on the back straight but a hell of a lot better car to drive.
Recently purchased a second hand set of 17x8 +35 and 17x9 +32 Volk Racing GT-P to go on the R33. Tyres going on to be Kumho KU-36.. Should be grippy enough. Picking up the front tyres next week, the rears will have to wait a week or two more until I save enough money.
Did some smallish things today, put new windscreen wiper blade/carrier things on it today, still got to take the arms off at some point and actually paint them so they are just flat black instead of half black/half unpainted metal. Will wait until it's warmer.
Purchased replacement leather gearstick/handbrake boots, and bought some random leather wrapped Nismo gearknob off eBay. *shrug*.
Got more stuff in the pipeline to do to the 33, then I'll have to get it out to a track day or two... Needs some suspension parts replaced before any of that happens though.
Fun times ahead, may involve corners!
even just putting that new suspension in will make it 20 times better to drive :P cant wait to see the custom work, send me a pic of it noob!
this a little update. wing uprights are cut out, just need to sand some file marks out, buzz them off with some 240g and I'll etch them up and paint them satin black.
they were such a bastard to cut out, 10mm thick alloy plate is nasty to work with by hand.
I'm still in the process of making the wing blades/ends. making dual blades, should have them done in a day or so
heres a pic with the bar on, its still in primer obviously, prob not going to rub down til i've got the front guards finished, they are going to get a bit more flare work, then prime.
the old man was onto me to fit the bar as we have a garage crawl with the classic ford club 2moro. They are prob not going to think too much of my jap crap anyway lol.
Edited by Mr. Untouchable
well, its mounted on factory bracing at the front points, and its on the edge of the boot at the rear, so already very solid.
however, I'm pretty sure I'm going to cross brace it with stainless wire trace and some nice neat SS turnbuckles and mount some anchor points at the front of the boot.
doing a simular thing with the splitter :thumbsup:
We did a day of testing on a big origen wing at baskerville. even on full downforce we didn't lose any top speed. It helped that the car came onto the straight 5-10km/h faster with the extra grip
if anyone in launceston is free and knows how to get a gearbox out of a fwd corolla let me know!
just about to have another crack at it now but its being a real PITA
picked up our new custom made catch can today to fill the hole in the engine bay were the battery used to be, will put some pics up tonight, just need to measure up the top mount bracket for it and fit the mini filters, polish in then all sorted, looks pretty with the speedflow fitting fitted up...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
