Well I've got the day off, and I'm making up my wing stands and have measured out my custom 'jack's backyard aerodynamics' wing ends.
360mm stands to get the sucker at basic roof line. The wing blade is a carbon jobbie with a sorta built in gurney flap, so, hope it works as well as looks.
and my dual wing blade/ends should be pretty unique, should have it close by the end of the weekend.
my ass dyno/aero effects-o-metre is light years ahead of that shit.
i'll test it by running with it at the track, then unbolt it and run with no wing and see how it compares.
I'm tipping around a 10-15k loss of speed on the back straight but a hell of a lot better car to drive.
Recently purchased a second hand set of 17x8 +35 and 17x9 +32 Volk Racing GT-P to go on the R33. Tyres going on to be Kumho KU-36.. Should be grippy enough. Picking up the front tyres next week, the rears will have to wait a week or two more until I save enough money.
Did some smallish things today, put new windscreen wiper blade/carrier things on it today, still got to take the arms off at some point and actually paint them so they are just flat black instead of half black/half unpainted metal. Will wait until it's warmer.
Purchased replacement leather gearstick/handbrake boots, and bought some random leather wrapped Nismo gearknob off eBay. *shrug*.
Got more stuff in the pipeline to do to the 33, then I'll have to get it out to a track day or two... Needs some suspension parts replaced before any of that happens though.
Fun times ahead, may involve corners!
even just putting that new suspension in will make it 20 times better to drive :P cant wait to see the custom work, send me a pic of it noob!
this a little update. wing uprights are cut out, just need to sand some file marks out, buzz them off with some 240g and I'll etch them up and paint them satin black.
they were such a bastard to cut out, 10mm thick alloy plate is nasty to work with by hand.
I'm still in the process of making the wing blades/ends. making dual blades, should have them done in a day or so
heres a pic with the bar on, its still in primer obviously, prob not going to rub down til i've got the front guards finished, they are going to get a bit more flare work, then prime.
the old man was onto me to fit the bar as we have a garage crawl with the classic ford club 2moro. They are prob not going to think too much of my jap crap anyway lol.
Edited by Mr. Untouchable
well, its mounted on factory bracing at the front points, and its on the edge of the boot at the rear, so already very solid.
however, I'm pretty sure I'm going to cross brace it with stainless wire trace and some nice neat SS turnbuckles and mount some anchor points at the front of the boot.
doing a simular thing with the splitter :thumbsup:
We did a day of testing on a big origen wing at baskerville. even on full downforce we didn't lose any top speed. It helped that the car came onto the straight 5-10km/h faster with the extra grip
if anyone in launceston is free and knows how to get a gearbox out of a fwd corolla let me know!
just about to have another crack at it now but its being a real PITA
picked up our new custom made catch can today to fill the hole in the engine bay were the battery used to be, will put some pics up tonight, just need to measure up the top mount bracket for it and fit the mini filters, polish in then all sorted, looks pretty with the speedflow fitting fitted up...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
