Definitely need HID's when I get some more coin! I don't need lights of a night anymore as I'm used to my LB's not doing anything!
jaycar have a hid kit in there for about 100$ but you can get them cheeper like 85? just ask :) they work a treat in my mates stag there the 6000K white ones 2 you just need the right kit because some times if you put the single beam kit in a insted of the dubble the HB doesnt work and wen you lights on HB the hid's will turn off 2 but.pinch.gif... with the hid kit you wont notice ur HB on anyways thumbsup.gif
Yeah i was going to do that but thought might be safe to have it so if i need to change them over i can thumbsup.gif
yer i cut my cannon off added a flange to the exhaust and put one on the cannon 2 so if i get sick of the bozo's i just unbolt it and swap them :)
jaycar have a hid kit in there for about 100$ but you can get them cheeper like 85? just ask :) they work a treat in my mates stag there the 6000K white ones 2 you just need the right kit because some times if you put the single beam kit in a insted of the dubble the HB doesnt work and wen you lights on HB the hid's will turn off 2 but.pinch.gif... with the hid kit you wont notice ur HB on anywaysthumbsup.gif
Ok sweet, thanks fir the heads up! Will go in a couple of weeks and check it out :)
getting a bit done to the ol datto at the moment. got half the sound deadener out on saturday, ran out of dry ice. picking some more up 2moro arvo to finish it off. I cut some more wiring out of the thing and FINALLY got around to removing the aircon. looking forward to getting it painted out inside.
also if anyone wants dry ice for removing deadener,
Malcolm Larner
TENS Dry Ice
20 Elderslie Road
Brighton TAS 7030
Mob: 0429 187 109
Email : [email protected]
sells 16mm and 3mm pellets, 3mm is what you want for doing the sound deadener jobbie. & minimum 10kgs.
Not much new with my whale, still sanding/polishing the cam covers glare.gif
Received my 2-UP stickers thanks to Antonio at 2-UP.com.au yesterday so slapped them on today.
I have been slack with my twin pipes but should be all sorted by the end of next month.
So my car wouldnt start after work today, mechanic came out and checked it out said its the fuel pump,
he recommended a walbro gss294 in tank pump
ive seen heaps of threads on bosch 044 ext pumps
just wondering what a similar bosch in tank pump would be? is it the 040 and would it be a better choice than a walbro?
i highly recommend the bosch pumps but in the past ive fitted genuine walbros and they are smaller and fit far better in a r33 fuel tank.
the 040 is not recommended for r33/s14 on due to the design of the pick up. it will give you fuel surge during normal driving under half a tank. the 044 will work better than the 040.
have a look around this site there would be literally hundreds of how to s and recommendations for a r33 gtst
after reading that I think I have a 040 as mine surges like bitch when it gets just under half a tank
Edited by Autumn33
I've got a walbro in mine. Works awesome except for when you spin out really fast it'll get a vapor lock.
Prolly should have a Surge tank...
Edited by zoidbergmerc
Im looking at upgrading mine cause i think mine is causing misfiring.. would i be best getting an 040 and just putting up with the surge? is it only a little bit at a certain amount of fuel in the tank? or all the time under half tank?
My old 33 had a 34 gtr pump in it and that seemed pretty good but dunno the price
my mechanic had already ordered it so im getting it put in i think mon, he said hes gonna mount it a bit lower to try and help but yeah i guess ill find out soon how it goes
I've got one out of xrated if you need one Pete.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
