Definitely need HID's when I get some more coin! I don't need lights of a night anymore as I'm used to my LB's not doing anything!
jaycar have a hid kit in there for about 100$ but you can get them cheeper like 85? just ask :) they work a treat in my mates stag there the 6000K white ones 2 you just need the right kit because some times if you put the single beam kit in a insted of the dubble the HB doesnt work and wen you lights on HB the hid's will turn off 2 but.pinch.gif... with the hid kit you wont notice ur HB on anyways thumbsup.gif
Yeah i was going to do that but thought might be safe to have it so if i need to change them over i can thumbsup.gif
yer i cut my cannon off added a flange to the exhaust and put one on the cannon 2 so if i get sick of the bozo's i just unbolt it and swap them :)
jaycar have a hid kit in there for about 100$ but you can get them cheeper like 85? just ask :) they work a treat in my mates stag there the 6000K white ones 2 you just need the right kit because some times if you put the single beam kit in a insted of the dubble the HB doesnt work and wen you lights on HB the hid's will turn off 2 but.pinch.gif... with the hid kit you wont notice ur HB on anywaysthumbsup.gif
Ok sweet, thanks fir the heads up! Will go in a couple of weeks and check it out :)
getting a bit done to the ol datto at the moment. got half the sound deadener out on saturday, ran out of dry ice. picking some more up 2moro arvo to finish it off. I cut some more wiring out of the thing and FINALLY got around to removing the aircon. looking forward to getting it painted out inside.
also if anyone wants dry ice for removing deadener,
Malcolm Larner
TENS Dry Ice
20 Elderslie Road
Brighton TAS 7030
Mob: 0429 187 109
Email : [email protected]
sells 16mm and 3mm pellets, 3mm is what you want for doing the sound deadener jobbie. & minimum 10kgs.
Not much new with my whale, still sanding/polishing the cam covers glare.gif
Received my 2-UP stickers thanks to Antonio at 2-UP.com.au yesterday so slapped them on today.
I have been slack with my twin pipes but should be all sorted by the end of next month.
So my car wouldnt start after work today, mechanic came out and checked it out said its the fuel pump,
he recommended a walbro gss294 in tank pump
ive seen heaps of threads on bosch 044 ext pumps
just wondering what a similar bosch in tank pump would be? is it the 040 and would it be a better choice than a walbro?
i highly recommend the bosch pumps but in the past ive fitted genuine walbros and they are smaller and fit far better in a r33 fuel tank.
the 040 is not recommended for r33/s14 on due to the design of the pick up. it will give you fuel surge during normal driving under half a tank. the 044 will work better than the 040.
have a look around this site there would be literally hundreds of how to s and recommendations for a r33 gtst
after reading that I think I have a 040 as mine surges like bitch when it gets just under half a tank
Edited by Autumn33
I've got a walbro in mine. Works awesome except for when you spin out really fast it'll get a vapor lock.
Prolly should have a Surge tank...
Edited by zoidbergmerc
Im looking at upgrading mine cause i think mine is causing misfiring.. would i be best getting an 040 and just putting up with the surge? is it only a little bit at a certain amount of fuel in the tank? or all the time under half tank?
My old 33 had a 34 gtr pump in it and that seemed pretty good but dunno the price
my mechanic had already ordered it so im getting it put in i think mon, he said hes gonna mount it a bit lower to try and help but yeah i guess ill find out soon how it goes
I've got one out of xrated if you need one Pete.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
