Hey guys im looking to purchase a stagea sometime soon, was looking at the 260RS, is there any differences between them and the autech version (brakes, suspension etc) or is it just the autech badge?
Thanks
Ok but do they have the brembo brakes or anything else GTR on them?
Or do they come with standard stagea brakes, suspension etc..
The ones i looked at didnt have the autech badge on them so i thought they may be different.
Does anyone have a 260rs that can tell me the differences, looked on heaps of sites but most of them only have the 2.5
Any problems with the import of the car?
Edited by (OO Black 33 OO)
Full GT-R running gear; engine, gearbox, rear cradle, Brembo's, 3-gauge cluster, and body tweaks by Autech.
There are a few '260RS lookalikes' out there that are non-Autech conversions. Note that all genuine 260RS' were WGNC34 RSfours that have been modified - they are body plated as being an Automatic RB25DET.
There are usually a couple for sale at about $25-$30KAUD
That's right. Further to this (and regardless of the fact that the build plate states that the car is an automatic RB25DET), Nissan's FAST software will be able to tell you if it is a genuine Autech 260RS when you put the VIN into it. If FAST doesn't confirm it, it's not the genuine item!
NOOB question, but do all stage's have attessa and HICAS or are they one in the same? just to help me clear some confusion i have, thanks scott.
Nope, Scott - only the AWD versions have ATTESA, and there are quite a few RWD Stageas here in Oz.
And only the factory manuals (RS-Four S in the series 2, and 260RS in both s1 and s2) have HICAS.
  • 3 weeks later...
hey i just read through this fourm and i saw that no1 said anything about wood grain cos mine is full of it, and also dose any1 have a 110v power point in the center console. cos i have read heaps about it and i havn't heard anything about.
i have pics aswell
i have pics aswell
I have woodgrain, but steering wheel is leather (25t x four) I also have the power outlet, I use it sometimes for the ipod with one of those powerpoint adapters you get from the supermarket
mine is series 2 rs-v prime edition do u have full leather? 6 stacker?
  • 4 weeks later...
Hi i´m new to this forum was locking for info about the stagea as i´m considering buying one.
I most apologize if my english is bad as it´s not my native language i´m from sweden.
I have found a stagea thats converted to manual and rb 26 in japan, so i need help to what to check, before buying.
Greetings from sweden
Hi and welcome!
The price conversion is $25kAUD, which is probably pretty reasonable all things considered.
Does that badge on the tailgate say '26X Four' ? (if it does, someone's having a bit of a joke and had the badge made up)
You should check to see if a modified car such as this can be registered - it would not be possible here in Australia to import and register this particular car.
It's still running the standard non-Autech brakes (see image #7), you'd probably want to consider changing them for something better if you plan on increasing the power output of the RB26. As per other posts in this thread - look for rust around the outside mirrors and around the front strut tops. Look to see how neat the conversion is (it looks ok to me.
You will have no true indication of the distance it's travelled due to it's non-standard condition.
Tanks for the help, the car is registred and finish to use, the importer say they have papers on that the conversion in japan is in standard to a factory car, so i´ll shall check for rust and if conversion is ok, clutch gearbox diffs elektronics etc.
Brakes i can get for good price: d2racingsports brake set.
  • 3 weeks later...
wow im way confused as to what i have now??
i got a feb 2001 rs four s,its manual awd with hicas and pearl white in colour and has 17 inch wheels,they look simuler to 34 gtr wheels,full body kit incld side skirts and rear wing,as far as i can tell i have all these options i think..when i closes the rear door(boot)it makes a weired noise like somthing electric like its locking or somthing,is this the auto door close thing mentioned??,can somone tell me more about my car,i was almost convinced for a minute i had a 260rs but am minus the 26dett,i must have an autech bonnet has the sticker under the bonnet says rb26dett( the sticker for idle speed and spark plug gap etc,any info on my car would be sweet
The rear door locking/whirring is exactly what you think it is.
Idle speed anywhere around 750-800rpm will do the trick. Plug gap of 1.1mm is fine assuming your coil packs are in good nick. IF you increase the boost and the spark breaks down you can lower the gap to 0.8mm or so.
RB25DET neo run 15deg advance btdc (not the 20deg of the RB26)
You should have R34 GT-t style seat.
Larger factory swaybars vs RS4.
That is a start anyway. All you need now is to get stuck into some mods.
  • 1 month later...
Hey :nyaanyaa: i am thinking of buying a stagea in the next couple of days - My choices are buy a series 2 with basic mods or buy a series 1 with all suspension upgraded , mods and stereo etc for around the same price.... I am concerned about standard suspension in both series 1 and 2 cars and it is making me only look at models with upgraded stuff as i have heard some pretty bad reports on suspension. I don't want to spend much more money after getting the car but did not know if a series 2 is ok as (stock / zorst cooler coilpacks) I know the trans, engine and some exterior features are different between the models but is it really going to matter once you start bolting stuff on to the engine?
Any advice would be fantastic and thanks in advance
Edited by uppon2
Hey :) i am thinking of buying a stagea in the next couple of days - My choices are buy a series 2 with basic mods or buy a series 1 with all suspension upgraded , mods and stereo etc for around the same price.... I am concerned about standard suspension in both series 1 and 2 cars and it is making me only look at models with upgraded stuff as i have heard some pretty bad reports on suspension. I don't want to spend much more money after getting the car but did not know if a series 2 is ok as (stock / zorst cooler coilpacks) I know the trans, engine and some exterior features are different between the models but is it really going to matter once you start bolting stuff on to the engine?
Hey mate, welcome to this section of the forums!
It comes down to a few factors when choosing a car:
  • If you want a factory manual, then your choices run to a series 1 260RS, or either the series 2 RS Four-S or 260RS models.
  • What do YOU prefer, looks and features wise?
  • Which of the cars you're considering buying is in better condition overall?
  • Have you checked out and compared insurance costs to see if they'd be the same?
  • What upgrades would you like to do that aren't on either car yet?
  • Were quality parts used for the upgrades, and was the work done to a decent enough standard?
  • Have you driven either of the cars you're considering buying, and how did they feel to you?
What bad reports have you heard about the suspension?
Don't forget, these are not exactly sports cars, so you can't expect it to handle "perfectly" considering the compromises that have to come with the extra weight and practicality of it being a wagon.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
