I would see 2wd as a big downside - compensated in part if it were a manual. Some RS models have no turbo.
I thought RS means "Turbo", the 4(FOUR) means 4WD. I have an RSFOUR and a 25G which is RWD,N/A, auto.
Another thing different between the 4WD and RWD is the front suspension. There is less offset on the 25G so I needed spacers to fit the 17X8s.It came with 17X7s.
  • 5 weeks later...
Has anyone got a definitive resource for S1 Dayz options? Ours has the dayz kit and badging so I presume genuine. Interior plastics grey/black, cloth, twin roofs, auto tailgate, LSD, nismo 'red' shocks/springs, nismo 2.5" cat back exhaust, wiper heaters, grille is chrome slat type. Interested to know what is likely optioned from new vs accumulated over time. It has s2 rear lights but I'm presuming they were fitted by the owner.
  • 4 weeks later...
Hi all,
This is my first post on this forum! My N15 SSS Pulsar was recently stolen, and I've almost decided to get a C34s2 RS-four S as my next car :D
I have my eyes on these two Stags atm: Modified and Unmodified
I was wondering how the prices of these two examples rate? Are they about right or a bit on the expensive side?
The VIN of the 2nd example is: 6U900WGNC34138456 - if someone could run it through FAST, i'd be much appreciative.
Cheers!
Hi all,
Cheers!
IMO go for the slightly more expensive one, i saw that particular one come up a couple months after i bought mine and thought dam, though it used to be advertised at $15,000 so ask the seller bout that. u will end up wanting to do alot of those mods anyway after a couple months of owning it.
*Edit - and the dayz bodykits look alot better then the standard one plus those second front fog lights are pretty rare
Edited by Pft shh 89
  • 3 weeks later...
Hi All,
Looking for some help with finding a good manual Stag, problem is I live in WA and everything for sale is not.
http://www.carsales.com.au/all-cars/results.aspx?No=0&Qpb=1&Cr=12&Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&sid=12FFA3A669BA&SearchAction=N&silo=1011&seot=1&Nne=15&N=1216%201246%201247%201252%201282%204294960181%204294963846%201622&trecs=18
Can anyone help me with acting as a sort of buyers agent?
Need someone who is going to be picky to give me honest feedback and has potentially owned one so they know what they should feel like and also what to look for..
Are any of the ones up for sale members?
I am tempted by the dealer option in SA....
Thanks.
Shane.
Have a look in the Classifieds section here and narrow your options down by doing a search with "Stagea" as your tag. There are always a few for sale here, and a majority are cars that are well-loved and cared for.
Hi all,
Cheers!
more expensive one.. i did when i bought mine and glad i did.. the one i got had about 10k worth of mods and was about 3k more than a stock one so to me it made sense to do that rather than forking out another 7k to do the mods yourself.
:D That's what I figured - drove it home from Melbourne yesterday and went on the Adelaide Stagea cruise today!
Hi All,
Can anyone tell me how common surface rust is in sills?
I am trying to buy a manual stag from over east ( I am in perth) and two cars i have got independent inspectors to have a look have found some surface rust in sills or boot floor.
First one was worse than the second, though the second had been black duluxed underneath.
The first had pretty bad bonus rust in the chassis side wall behind the strut top near the abs module... straightened out front hit?
I am guessing these are snow region cars.
How common are steering rack leaks?
Should I:
A) Wait, consider my inspection fees as gone to experience (still cheaper than flights) and try to wait for a clean one to come up
B) Use it as a tool for haggling, and deal with it by not looking too hard underneath.
I am mainly looking at dealer cars as I figure organising transport etc might be easier.
Anyone selling an RS4S in Perth?
get a straight one
or buy mine
they will nearly all have rust under the wing mirrors, but rust elsewhere isn't too common (unless its a cold pack car)
it would probably be worth importing one yourself if you can't find what you want locally, then you can specify stuff like sunroofs, dayz options, jap wheels, mods etc and save yourself quite a bit!
but your doing the right thing with the inspections be cause buying a lemon could potentially cost your $$$$$$$$$$$$$$$$$$$
Sorry champ but your in tasmania...
Thats a boat, truck then train....
have you just been looking at dealers or private?
because there are heaps for sale privately and they are so cheap now :(
Thanks for trying to sell me you cars from states even further away...
Ended up sticking with dealers.
I hope it goes on the truck tomorrow and is in WA by Friday but I think i will be lucky....
Better not be rooted....
  • 1 month later...
After someone's thoughts on this:
http://www.carsales....id=133054BF324F
Any good or no?
That one has been for sale for ages! It was available when I got mine 3 months ago (to the day).
Over priced for what it is. For that money you could get nicer, with some mods and dayz options. Check out Robbie's car in the classifieds.
Only difference is Robbie's is auto, but it is tiptronic.
Really, Robbie wants $15500 for his, and it's a great car, great colour. Surely for the $1500 difference you could do a manual conversion if you needed a manual?
For $17k you are starting to look at clean, standard M35s, or maybe even a 260?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
