Here are some pics of my final FMIC installation. I got the car back from Springy Motors earlier this week and am absolutely stoked with the outcome (see dyno thread http://www.skylinesaustralia.com/forums/in...t&p=4719149 )
I removed the front bar, as I wanted to replace the black mesh inserts to 'hide' the cooler a bit. You can see what the 'Cooling Pro' Stealth FMIC looks like behind the bar here. For $150 I had George at Springy Motors fabricate some brackets to allow the bottom cooler mounts to attach to the frame (the brackets provided in the kit don't attach to anything)
I hand-sanded the angle-grinder trimming behind the bar, and did a dry fit with the mesh held in with masking tape. I had to trim the cooler piping clamp bolts with a grinder to make some room, and when I was happy with the dry-fit, used some 'Sikaflex' glue purchased at Autobarn to fix the mesh in place. I put a few bricks on it overnight to make a good bond.
I then trimmed away excess glue, re-attached the front bar, and did up all the bolts holding all the undercarriage plastics in place. All in all pretty happy with how the whole thing turned out. It looks pretty tidy, and turned out to be quite 'stealthy' after all. My advice for anyone considering a Cooling Pro Stealth on a S2 would be to just budget around $150 to have it professionally fitted - you'll still be a whole lot in front of buying a Greddy kit!
post-52103-1247992138_thumb.jpg post-52103-1247992383_thumb.jpg post-52103-1247992706_thumb.jpg
  • Replies 254
Posted Images
Looks great Tommy. How much did you have to trim off the front bar to get it all to fit??
Hey Sabbai,
I would estimate I trimmed about 60-70mm from the inner vents. Basically, (on a 'Dayz' bar anyway) you need to make the inner two vents flush with the outer vents. I'm not sure why the inner vents extend further into the engine bay than the outers in the first place, but they've gotta go. You could trim a bit more off to allow a bit more room, but I didn't want to make those vertical 'struts' either side of the numberplate any thinner than required.
PS
Very nice install Tangles! That looks seriously tough.
Hey Sabbai,
PS
Thanks Tommy. My Dayz Edition arrives late August and I'm wanting to get a cooler into it, but I didn't want to hack the front bar up. I like the way you've fitted it, as it looks to be done very well.
Looks good Tangles.
This is how i did it. I cut 1cm out of the lower part of the front bar, and got no problem at all with the clearance. :devil:
Nice install guys ..... just thought I would say to all stagea owners thinking of putting on a big front mount I/C
Take note !!! make sure your radiator is in good condition!!! get it cleaned or fixed!! as stagea's and r33's only have a standard 1 core radiator!!(many other sports cars have three or four core radiators). And if radiator is half full of junk(As japanease dont like putting coolant in cars) it is alredy putting stress on motor/cooling system then if you reduce air flow with a front mount then overheating/extra/engine stress could result blown head etc or worse big $$$ So for the cost of around a $100 or so to get your radiator rodded/ cleaned out it's cheap and could possibly save you heaps. Just trying to save stag owners $$$ Trust me fixing head gasket on stag is a F***Bitch of a job. Stag on!! ;)
Total cost below 5000sek (approx 750 AUD)
Hey guys,
just thought I'd add my (Very recent) experiences on the front mount issue. I ordered a Just Jap "C34 Stealth" kit on Monday, received it very happily on Wednesday. To start of with, the front mount is now fitted and looks fantastic. The car boosts stronger, faster and higher, or so it feels :blush:. Fit of pipes up to stock set-up was absoloutely perfect, and the core looks a treat. The one gripe I have with the kit was the fittings (Silicon was fine. Hose clamps were great though!). To be honest, the brackets and fixings supplied with kit fit absoloutely nowhere. For example: It was necessary to add another 40mm to the supplied spacer lengths in order for the intercooler to sit off of the fan unit. This in turn meant I had to replace the supplied mounting stud with a longer unit to suit the new spacer lengths. When pairing the supplied nuts with bolts of same diameter, some of the nuts would not thread onto the bolts, any of them. The supplied brackets seemed to attach to nothing whatsoever, in any configuration (Nth to Sth orientation vs. East to West orientation.) which meant I need to purchase new angles and fabricate them to suit the application. To tell you the truth, the problem solving process and fabrication was an entertaining surprise, but not an anticipated one :P
In short, if you purchase the same JJR C34 Stealth Intercooler Kit, expect to:
-Buy new fixings, spacers and brackets: ~$50
-Extra fabrication time: ~1hr
N.B.: This was fitted to a 1998 Series 1 Stagea, "Dayz Edition". No trimming of the Front Bar was required :down:
Big thanks to Chris for the 8mm driver and his time tightening clamps and fitting the bar!
harts.
  • 1 month later...
Nice work Tangles! That cleaned up pretty nicely after the gaping hole I saw in the bottom of your front bar at a cruise once, and the intake pipes held in with cableties! That's a very nice looking Stag.
PS Where did you get that lower-lower-lip-spoiler?? That's awesome
Edited by DaveB
  • 5 weeks later...
Here's mine after throwing on the Blits front bar + sideskirts, and a HDI GT Spec R32/33/34 FMIC.
As will most coolers I had to do the following:
Cut a hole in the battery tray,
Trim the fan blades,
Cut out 2cm of the intrusion bar
Trim a fair bit of the front bar.
Create slightly larger holes where the factory piping went through (under the air filter)
I didn't move the transmission cooler, but if I relocated it, the cooler would most definitely sit better.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
