I need to know how to get the 4WD to work on an R32 GTR that has had the ABS unit removed. The 4WD and ABS dash lights are on and the error code flashes to indicate a problem with ABS (error code 8). All other sensors are still in place except for the ABS unit. I have also just fitted programmable aftermarket ECU.
Any ideas?
https://www.sau.com.au/forums/topic/93554-4wd-not-working-after-abs-removal/
  • Replies 48
great help and a useful post thanks T04GTR.
NXTIME, there are two prong pulse wires that run of a magnetic pickup on each corner of the gtr. When you remove the ABS you have to disconnect this. Those wheel speed sensors also work for the Attessa. Follow the wires back to the body harnes and you will see where they diverge and go back to the ETS control computer located on the parcel shelf. Okay so work out which wires run to the wheel speed sensors from the wiring digram of the ETS that is in the workshop manual, work out the colours etc and trace thses as far forward as possible then extend the wires to reach their respective wheels speed pickups, buy two new plugs that will fit the originals and this should solve your problems!!! Does this make sense??? LEt me know if you need any more help I am sure I have the wire colours somewhere but it can be worked out! Cheers
so basicly. you have to indipendantly re run each wheel speed sensor wire back to the ets ecu. :P
as far as im aware its all hooked up. just the pump/actuator has been removed.
and fault code 8. (abs motor relay/circut etc) not a wheel speed sensor fault.
i thought the atessa ecu controles the abs?
i know this is a tricky one but somones had to of done this before.
i simulated this at work on my own car by unpluging the abs.
i got code 8 and 9.(abs motor relay and abs actuator relay)
any feedback on the same senario would be apriciated.
ps. this is nxtime and myselfs little chalange due to an aftermarket ets controler having been nikked from his car while on the docks.
lies! r32 gtr N1 do not have abs but there attessa still works
ok if they dont use abs sensor of wheel speed (wheel slip) how does the unit detect wheel slip. Does the N1 still have the abs wheel sensors it may not have the abs but i would put a good bet the sensors are still in place.
Charlie I will reply to your PM here. Also sorry didnt realise there was an in joke my apoligy's Dave.
Righto the ETS computer has 4 inputs that run from the the respective wheel sensors. Now the wheels sensors are magnetic pickups that run a pulse back to the computer which then calculates wheel speeds. Now for the 4wd the computer notes how fast all the wheels run in relation to each other and monitors if the back wheels run faster than the fronts, too compensate buy actuating the Attessa pump and engage the front wheels. Now, when removing the ABS which also uses these wheels speed sensors the 4wd computer doesnt have the inputs any more so its a matter of connecting them back up. All I did on my car is work out via the wiring schematics the colours of the 2 front wheel speed sensors traced them back to the ETS ecu chopped them and ran new wires right to the front, from the ETS computer, got a new plug and connected them up. I havent tried my car yet so I cant say if I had success but this is how I saw it done on Domenic's yellow autostyle car, that had the ABS removed. I hope this makes more sense this time.
i dont understand why you would want to get rid of the ABS in the first place? someone please explain that too me.
and 2nd, my dads boss races 2 r32 gtr's N1 spec and one of them which is all standard ecu's, if the ecu detects a wheel lock up it disengaes the front wheels until the car has completly stopped and turned off and back on again.
they tried it without the abs and the times were slower hence the abs helps.
as has been said above the speed sensors is what does it they have tried 4wd aftermarket controllers and the like still does it, they are running about a 40/51 front rear split.
there is away around it without all this wire chopping and the like you know, and you could take out about 20 or so kg of weight too.
SSS_Hoon
Thanks for that, Daniel :D Will try it and let you know how it goe4s.
SSS_Hoon, I think you will find that most drag cars have the ABS removed. Also, please enlighten us on how to get around the lack of ABS and also on the weight saving? Might as well kill two birds with the one stone.
they aint drag cars they are circuit cars sorry i forgot to add that.
i dont know for sure as tehy aint tried it yet but the theroy it should work,i dont want to post it up and have someon go and do it only to find out that it dont work.
but as for the weight it involves getting rid of all the abs stuff loom ecu resovior pump and what ever else is involved with it, the only thing is you will have the light on constantly(take out the globe) and the 4wd will be on constantly also.
SSS_Hoon
the n1 ATTESA computer is different and that is where the ABS signal is stopped in an n1. ie if you run an n1 ATTESA computer in a regular GTR you loose ABS but keep ATTESA.
Not sure exactly what the difference was in the N1 computer, it seemed to react quicker with front torque but it was not as good as a controller
cool. ok. im looking at the attesa schematic and the wheel speed sensors hook DIRECTLY to the atessa ecu.
i know everyones trying to help but the wheelspeed sensors are NOT the issue.
what we are trying to do is make the attessa ecu think its still plugged in to the abs/actuator assembly.(passanger side of engine bay with all the brake lines etc)
and no we dont have the abs/actuator unit. { the abs ecu is the attessa ecu(r32)}
for those with a manual refer to page ch-66
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
