94 GTR
Stock Bottom End
R32 Nismo Turbos
Tomei Camshafts 260 IN. and 252 Ex.
Apexi twin pods
550cc injectors
Sard 270ltr intank pump
Cam Gears (not tuned)
E-Boost
Chiped Computer (PITS)
CES Dump Pipes
3inch Xorst (cat back)
RB25 A/F Meters
310rwkw / 414hp
Edited by Ants
95vspec 33GTR
Motor built by JHH, Tuned by PITS and spanner work done myself...
Internals:
N1 Block cryo'd
Brand new crank fully polished and cryo'd
Argo's and Je piston's
Tomie oil pump and sump extension.
1.5mm restrictor, external drain to sump.
1.2mm hks gasket
arp head studs
big port job
full ferra valve train, double spring, titanium retainers, 1mm+ inlet valves, 2mm+ exhausts ect ect...
tomei cams 260in 10.2mm 270ex 10.2mm, adjustable cam gears.
Big fuel sytem
POWERFC pro and split fires
Hks 2530's on extrude honed standard manifolds (UAS)
CES Race dumps with extra long wastegate pipes and full stainless 4inc system(CES).
PPG straight cut dog box upgraded input & mainshaft
Jim berry clutch solid centre modified exceddy single plate pull type (drives amazing for solid centre)
586hp dyno sheet was done the same day as run .083 (PITSsheet) which was 550hp.
.093 was 1month later just before we added the tolulene
.098 was run with 33% tolulene mixed with ultimate tune didn't change just added 5degrees
and turned the boost controller to flat out.. (wastegates need more pre load)..........
Upgraded from the hks actuators to gcg 22psi units, more tunning soon....
EDIT. Bit more tunning today. very happy with the way it drives now as i didn't get to drive it last time with the tolulene only dyno it.. Today with the 586 tune we added 33% tolulene to 98 with no extra boost and made 605hp then i add the extra 5degress and then went 648.7hp. Its amazing what a couple extra degress will do..
Ryan.
Edited by Ryan1200
Further to my post a page or 2 ago here is a vid of my car on the dyno and free plug for the tuner
http://www.pulseracing.com.au/DynoTuning.htm
While his shop/site is only new, he has been tuning for years in Sydney, Bris, Melb, Perth and SA
along with overseas contracts and even tunes for shops in Sydney on a subcrontract basis!
I have known him for atleast 7 years (worked with him for 4) and have see this first hand but
wont name any shops
He will upload some details of a mates RB30/25/GT35 combo which is making 450 rw hp on 15 psi on JEMS Dyno.
DRIFTCATS S13
URAS DEMOCAR (old engine bay pics )
INTERNALLY STD RB26 (NEVER OPENED KINDER SUPRISE FRONT CUT)
EMANAGE ULTIMATE PLUG AND PLAY WITH OPTIONAL PRESSURE SENSOR RUNNING NO AFM'S
700CC BLITZ INJECTORS
TRUST T517Z'S TURBO'S WITH 8CM HOUSINGS (BABY'S)
TRUST INTAKE AND COOLER PIPING KIT
115MM TRUST R-SPL COOLER
GIZZMO PHENOLIC INTAKE GASKETS
HKS METAL THROTTLE BODY GASKETS
JJR ALLOY PIPE KIT
STD DUMPS
TRUST MILD STEEL FRONT PIPES
TRUST PETIR 80MM TITANIUM CAT-OUT EXHAUST
312rwkw @ 16psi OR 1.2bar
Response was the major requirement and it has delivered decent power too at a nice low boost level.
Edited by URAS
1996 Series 2 GT-R VSpec
Stock engine and turbos
Apexi catback exhaust
Blitz pod filters
Boost restrictor take out = 14psi
195.5kW at all fours (i think it hit the 180 limiter and cut out,not at max rpm, stock power shouldnt be on the climb at 8000rpm)
Still has the factory R33 computer which is leaning out at this boost level and no tune...
R34 GTR 2001, mildly modded
Apexi Pfc
Apexi EBC
Apexi pods
HKS split dumps
HKS front pipe
HKS catback (de-CAT)
HKS cams
Nismo twin plate clutch
stock everything else, 269rwkw @ 17psi (stock turbos)
mods to come (when i get around to it) HKS GT2530's, HKS 600cc, Tomei 260/260, Nismo AFM's
Edited by andz
96' GTR33
Garrett 2860R-5(HKS 2530 Equivalents)
Hks Split dumps
Tune agent manifolds
Nismo oil pump
Nismo water pump
Nismo fuel pump
Nismo fuel regulator
700cc Sard injectors
Iritop sparks
Split-fire coils
Trust oil cooler,with relocation filter.
Cusco catch can
Tomei air intake with Pods
3"Cat, Custom 3" exhaust,3" Resinator :wave: with 3" Xforce Hotdog
Apexi power fc
AVCR boost controller
ARC FMIC
HKS Cam gears
@ 4 Wheels
Max Power 260.3kW @7183RPM (1.3 Bar)
Max M.A.P 223.6kPa @7055RPM (1.3 Bar)
Future plans> Z32 AFMS, Tomei Poncams 260 Degree with 9.15 lift . :(
Fitted RB25 AFM's
Tomei Poncams
@ 4 Wheels
Max Power 274.7kw @ 6963 RPM (1.3 BAR)
Max Torque 924.8 Nm @ 4803 RPM
Max M.A.P. 230.4 kPa @ 4665 RPM
The Boost controller was not set up correctly the last tune....so reflecting the before tune curve.
98 Stagea Autech wagon
Rebuilt motor
CP forgies
REV rods
N1 Group A turbos
TuneAgent exh manifolds
HKS dumps, Nismo front pipe, Trust PE2 exhaust
Blitz 102mm cooler
Std afms (have z32s waiting)
Pods on CF tubes.
Sard 720's
Tomei cams (both set a zero)
044 pump
Greddy rail
301rwkw @ 16psi.
Soon to be retuned by Dr Drift with cams dialled and z32's fitted. All in the Darwin heat too!
Ran 488.9rwhp at powercruise 9. Gas goes on soon.
R32 GTR rebuilt engine with all the usual support mods etc etc
Airflow improvements:
Tomei cams 260/260 9.2mm lift
HKS cam gears set at -4 exh/+4 inl
Garrett -5's turboes with HKS split dumps HKS Super Drager exhuast system with no cat
Flowed and ported head ( work of art actually )
Greedy inlet piping kit, Trust intercooler and piping kit
8.8:1 compression
0.5mm over forgies
PFC computor tuned with FC Datalogit by myself > awesome software a must have!
RB25 AFM's
Run up on a 2WD Dyno Dynamics Dyno:
Boost running at 17psi > 311 RWKW
Boost running at 19psi > 365 RWKW or 488 RWHP
Torque 7200N at 19psi in 4th gear
Full boost reached at 4000 rpm, very responsive !
All this with a 8.8:1 measured compression ratio on 95 Octane fuel.
Fuel burn breaking down at 20psi and becomes unstable resulting in much less power.
Will get some race fuel and try again at 20+psi and see what happens.
Will post dyno graphs soon:
Edited by The Alchemist
1990 R32 GTR
Split fire coils
HKS 264/8.9 cams
OS Giken cam gears (not tuned)
Sard 850cc inj
Bosch 044 intank
stock internals/cooler etc
Jasma cat(less) back
HKS T45 S Spl turbine kit (cast manifold 50mm ext gate 4" dump, screamer)
RB20 afms
Apexi pods
Apexi Power FC
411.1 rwhp@ .7 bar
Rebuilt engine results soon..
Ceramic coated .5mm o/s CP forgies
Teflon coated skirts
Eagle Rods
King bearings
N1 pumps
HEad tickled
Port matched manifolds
Apexi 270/8.9 cams
Nismo head gasket 1.2mm
Blue printed/balanced crank (9000rpm)
Jun collar
Z32 afms
Ceramic coated exh manifolds/turbo/wastegate
Greddy Eo-1 ebc
Billet fuel rail
Sard fpr
Tomie sump baffle kit
Mines rocker cover baffle kit
Trust R intercooler
Apexi hard pipe kit
Aiming around 6-650 rwhp @1.5-1.8bar
Has already run 12.1@120mph before rebuild
Edited by CMS Drifter
R32 GTR
86.5mm Arias Forged Pistons
Shot peened rods & ARP bolts
Extensively modified crank,grubscrewed etc: c/w custom pump drive collar
Jun Hp Hv oil pump
Custom 7.5 litre gated sump
Remote oil filter / and 24 row Earls oil cooler
262º degree cams
Vernier cam gears
Grp A Valve springs
JUN Bronze guides
Nismo head gasket
Gibson Motorsport Nismo RS581 Le Mans turbo's
Gibson Motorsport Exhaust manifolds
Ported head & manifolds port matched
HKS actuators
SS equal length front pipes
ARC intercooler
HKS hard piping kit
Twin entry custom fuel rail
Sard Fuel regulator
Custom 90mm Exhaust & HKS rear can
Modified Apexi pod filters
Custom Aluminium 3.2 litre surge tank
Bosche 044 motorsport fuel pump
Dyno sheets available - 360wkws @ 1.3bar on 96 pump gas
Edited by RS581
  • 1 month later...
1998 R33 GTR
Stage 1 at 0.85 bar - 348hp (260kw) on 98 pump fuel
GT2860-5
Adj cam gears
PFC+EBC
Custom 3" Dumps/top pipes
Metalcat
Kakimoto 3.5"
Sard 700cc
Stock cams, stock airbox and filter, stock AFMs
Tune and tweaked inlet cam timing.
Stage 2 - More to come with boost, better panel, RB20 AFMs , exh cam timing and better cold air induction
Edited by WRRR
RB26 Standard block with oil and water gallery mods
R33 crank
ARP head and main studs
Jun rods
Jun Pistons
Jun 266 deg 9.6mm lift cams
ACL Race bearings
Ross balancer
Peterson Dry sump with peterson filter
Minor head work
Standard intake and throttles
6 boost manifold
t76 custom mr turbo CNC alloy core
117mm bar and plate intercooler
Made 727.5hp on 28psi @ 7700rpm with light tune as no time before the nats to degree cams and add timing
This was with Shell Vpower fuel with no additives
Am currently in the process of putting 280 deg cams
Water injection
Water intercooler sprayer
More port work
and Autronic SM4 so will post up new dyno readings when finished
SKMBT_C45007010908290.pdf
Hey guys,
My car is a 2000 R34 GTR.
Engine internals are standard.
Tomei 1.2mm metal head gasket
ARC Intercooler
ARC Prestege Radiator
Trust oil cooler
HKS 660cc injectors
HKS fuel rail
Trust intake plenum
Apexi pod filters
HKS 264/264 step 1 cams
Cam pulleys
HKS intercooler piping
Blitz Nur Spec 110mm i think full exhaust system
AutoSelect Tuned lenght front pipe
HKS GT Extension kit
Jun Oil pump
Nismo intank fuel pump
sard fuel regulator
PowerFC + 2x RB20DET AFM's.
Turbo's are twin HKS GT-SS turbines
Car was tuned by Eiichiro of autoselect (www.autoselect.co.jp)
Currently doing 467whp at 1.55 bar.. :P
92 r32 GTR
stock internals
tomei poncams
HKS GT2530's
720cc inj
nismo pump
Fcon v pro
yada yada yada
Done with bone stock airbox in place!
299.5 RWKW@ 0.9 BAR
340 RWKW@ 1.27 BAR (full boost at 5250rpm)
Dyno sheet to follow.
R32 GTR RB26DETT
Possibly n1 engine as is gold?
(Internals uknown)
Hks 2530 turbos
Cams (Unknown)
3" Hks Dumps
3" Hks Fronts
3.5" Hks Exhaust
Mines Ecu
Hks Oil Cooler
Power run gave 264rwkw at 15psi
Will tune wen i get the following hoping for 340-360rwkw( twin nismo afms, power fc, bosch 044, apexi ebc, sard 800cc twin sprays)
  • Like 1
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
