  1. fresh engine
  2. hid boost controlla
  3. gtss turbos
  4. tomei dump pipes [so fu*#%n expensive but worth it]
  5. n*power y pipe
  6. 200 cell cat then 3inch pipe into a 3inch cannon.
  7. nistune computer the computer makes a diffrence
  8. jc forge pistons but i dont think that that would make any power diffrence
  9. ajustable cam gears
  10. walbro 400lph fuel pump
  11. 1999 nissan stagea 260rs 271.4kw @ all 4s :bunny:
  12. how do i post a pic up???
Nissan R32 GTR 1993
Engine
High Octane Cam Baffles
NGK Spark Plugs
Yellow Jacket Coilpacks
HKS 264Degree 8.8mm lift Camshafts
Tomei Adjustable Cam Gears
Stock Head
720cc Sard Injectors
Stock Fuel Rail
Nitto Intake & Exhaust metal gaskets
Nitto Full Gasket Kit
ARP Head Studs
ARP Main Studs
ACL Race Big End Bearings
ACL Race Main Bearings
Cosworth 1.1mm Head Gasket
CP Pistons 86.5mm
Nitto H-Beam Rods
1.5mm oil restrictor
33 GTR Crankshaft.
JUN Oil Pump
N1 Water Pump
Gates Timing Belt
Ross Harmonic Balancer
Tomei Sump Baffle Kit
Standard Sump
Bolt ons
Standard Manifolds (Ceramic Coated)
Standard Plenum
Twin Turbo Pipe Air Splitter Mod
Apexi Power FC /w Hand Controller (Not D Jetro)
Garrett 2860-5's turbine housing both ceramic coated
Turbo Braided Oil and Water Lines
Tomei Extreme Dump Pipes
HKS Front Pipes
HKS Piping Kit
HKS Hi Power Cat Back Exhaust
Nismo Twin Plate Supercopper mix
HKS EVC 5 Boost Controller
Cooling Pro 42mm Aluminium Radiator
Z32 AFM's
Earl's Oil Filter Relocation Kit
Earl's Oil Cooler 18 Row /w Braided Lines
Custom Oil Catch Can
ARC Front Mount Intercooler
Aftermarket Fuel Pump
Tuned by Unigroup Engineering
370.5 RWKW @ 22psi
  1. fresh engine
  3. gtss turbos
  5. n*power y pipe
  11. apr stud kit
  12. nitto gaskit kit
Finally got on the rolllers today, Didn't lean on it too hard! wanted to keep it safe!
Standard RB26 with GT3582R .82
precision 48mm wastegate
Platinum pro plug in
Made 359.3hp on 14psi
Planning a forged 26/30 in the near future!
1996 R33 GTR
N1 block, unknown internals
T88
Sucrogen E85
590awhp (hub dyno) @ 22psi
1000cc squirters maxed out & blowing spark out. New tune to come with ID2000's & HKS Twin Power or similar running 30psi
Edited by VSPECII33R
1995 R33 GTR
120.000 km on clock
ARC front mount cooler with stainless steel piping
Upgraded fuel pump
Stock airbox
Nistune
oil cooler
ebay front pipes with 3 inch stainless steel exhuast de dat with verex tip
stock dump pipes
everything else stock
14psi on stock turbos made 335 rwhp.
R32 GTR 1993
HKS GTSS Twin Turbos
Nismo front pipe
HKS Dumps
Hks Exhaust
Nistune
Walbroo 400 lph Pump
650CC hks injectors
This engine has been rebuilt recently and has 9.1 comp.
Tuned by DVS Tuning
13.5psi 273rwkw. coilpacks failed at high boost im going back in a month to see what it makes with spitfires and cam gears.
Edited by Anz32GTR
Rb25 Block
CP Pistons
Eagle H beam Rods
Neo head with Solid Lifters
Tomei Cams
Rb25DET Oil Pump
ARP head & Bottom End Kit
Custom Winged Extra Sump 2L
60mm Waste Gate, HKS Air Pod
ApexiPower FC, Splitfire Coil Packs
2x Walbro 550HP Fuel Pumps
Rochester 1000cc Injectors
Custom TTR Fuel Rail
Malpassi Fuel Regulator
Borg Warner S400 Turbo with .9 Rear Housing
HKS Style GTR 100mm Tube Fin Intercooler
ACL Race Series Bearings
UAS Spilt Pulse Exhast Manifold, 3 Inch Exhaust
HP= 423
kW= 315
Edited by PranK
Fix link
GTR r32 silver 93
79km
Le mans turbos
Tomei cam gears
HKS ehxaust
HKS dump pipes
Z32 afm
Nismo 555 injectors
Hi flow walhbro type petrol pump
Nistune ecu
Nismo main bearings
N1 water pump
Silicone hose kit
ACL race big end bearings
Greedy boost controller
Dyno run 27/04 316.1kwatw @ 20psi
Update:
Now with adjustable coilovers , straight trough pipe with hiflow cat and HKS cannon
Carbon pod filter cover
Alarm with keypad fitted
Future mods
Spitfire or OEM coilpacks
Larger injectors
Second highflow fuel pump
Catch can
  • 3 weeks later...
Standard RB26
2859-9 Turbos with HKS Actuators (GT-SS)
Racepace Cam Gears
HKS Front Pipe
Tomei Expreme Ti Catback
PowerFC D-jetro
PowerFC Boost Controller
Apexi Super Suction Kit
Sard Fuel Pump
Nismo Fuel Reg
Nismo Super Coppermix Twin Plate Clutch
309kW rear wheels @ 18psi :)
block machined , balanced , honed oversized 0.20
crank , remachined and re heat treated , oversized acl race bearings
rods , shotpeened and prepped rods with oversized acl race series big end bearings
pistons arias forged 0.20 oversized with acl race series rings ect
tomei oil restrictor
cossworth 1,5mm drag series metal head gasket
n1 water pump
nitto high flow oil pump
nismo low temp thermostat
trust oil filter relocation
tomei sump baffles/trap doors
brand new gasket set throughout
head reconditioned with
hks step 2 cams and valve springs quite lumpy
slight porting on exhaust side
greddy adjustable cam gears
turbos , brand new garrett -5 turbochargers
hks non turbulent dump pipes
twin 3inch up pipes with 3inch magic cats (100cfm)
single 3.5inch high flow system
5inch rear cannon
autogallery yokohohama/os giken 1-5 gearbox , custom double cone syncros , hd mainshaft , hd input shaft , one piece billet 5th gear built by terry at award in sydney,,,
brand new os giken twin plate clutch
vspec active rear lsd and axles ect
nismo 320kmph dash
apexi power fc commander with hand controller
blitz ebc
injector dynamics modified 1000cc injectors on standard rail
turbosmart adjustable fpr
bosch 044 pump
splitfire coilpacks
hks dli twin spark amplifier
tien adjustable suspension
412 - 418kw @ 25psi still on 98
Edited by vrkt33
n1 water pump
5inch rear cannon
nismo 320kmph dash
blitz ebc
bosch 044 pump
splitfire coilpacks
U can see the Graph here as i dont know how to put it up on here -_-
http://www.vicimportsclub.com/forums/thread-6114.html
R32 GTR with R33 GTR engine
new king bearings + sump baffle etc, standard pistons
trust t517z turbos
76mm HPI stainless dump pipes to 65mm front pipe and 3" cat back
ARC 70mm front mount
sard 700cc injectors
bosch 044 intank pump
power fc
blitz i-colour boost controller
apexi pods
OS Giken twin plate solid center clutch
331.6kw safe tune to match standard internal engine
bigger front pipes and cat back are next, plus tomei type B cams then retune.
retuned but added:
twin 3" to 3.5" front pipe
3.5" super high flow cat
3.5" cat back
Tomei cam gears
MUCH much better response and midrange
Edited by SiR_RB
320kw @ 20.1psi
HKS GT-SS
Tomei Type B poncams with tomei cam gears
Haltech PLatinum pro running on MAP
Apexi pods
Hard intercooler piping with 100mm intercooler
KTS hard piping intake kit
Greddy Oil cooler
Stock dumps
3 1/2 inch front pipe
Apexi N1 catback
Nismo radiator
Nismo thermostat
Jun lightened flywheel cushioned button clutch
Greddy Air/water seperator
blitz boost controller
Nismo fuel pump
750cc injectors
Edited by sinistaGTR
Engine Mods
n1 water pump
5inch rear cannon
nismo 320kmph dash
blitz ebc
bosch 044 pump
splitfire coilpacks
Stock RB26 including stock cams
Precision 6262 .8 twin scroll
6boost twin scroll with twin tial 38mm gates
Custom dump and plumb back pipes
LINK ecu
ID2000 cc injectors in stock rail
Walbro 400lph
Running semi slicks on the dyno too
Gate pressure
E70
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
