  • 4 weeks later...
Dandan Automotive forged RB26 with complete Nitto parts list including oil pump
prepped R33 crank
DA custom cams
Apexi V-Max springs
cleaned ports
-5 turbos
RIPS sump
ATI blancer
Adaptronic ECU
Walbro in-tank pump
ID1000's
Turbosmart FPR800
E-Boost 2
stock cooler, piping and inlet
HKS dumps, front pipe and 3"-> 3.5" HKS HiPower exhaust
350rwkw@18psi on V-Power 98 on soft tune by Dandan Automotive
Going back for more boost and tuning soon.
  • Like 1
R32 gts4
Unopened r32 gtr motor
R32 n1 turbos
Splitfire coils
1000cc injectors
E85 safe 500hp bosh pump
3.5 catback ebay special
Adaptronic ecu
354rwhp 98 pulp 18psi
404rwhp E85 107 octane 18psi
Cant add pics dont know how
GTR-R33
Standard unopened engine
Brae high mount manifold
HyperGear HPVA 50mm external gate
1000cc ID Inejectors
Haltech platinum Plug in ECU
HyperGear ATR45 Special application Turbocharger In Ceramic ball bearing
600x300x100mm intercooler
3inches turbo back exhaust
401awkws@24psi E85 fuel.Running against factory twin T25s
The response on that is mighty impressive
Can you give a graph with both at same boost level ?
Using turbocharger above I only have results based on two different boost levels:
Very light blue: 21psi make 380rwkws.
Orange: 24psi make 404rwkws.
Dark blue lines are from a different prototype used for comparison, that is irrelevant to this test.
Rb25 neo stage 2 tommi pon cams greeddy inlet hi mount manifold gtx3582r. Thanks for the tips to run a .82 rear waste of time should of gone for the .63. Comes on boost very slow. Full boost by 6000rpm made 394rwhp at 6500rpm dyno cut out so didn't get a full read out. Looks like its heading for 420+rwhp. See dyno photo
93 r32GTR
Stock unopened engine
GT2859R-9s with Garrett wastegates
ID injectors
Aeromotive pump
HKS cam gears, very small adjustment
Vi-pec plug in ecu
nicest feeling tune yet, car drives just like factory with awesome response and good shove. Far better tune than previous places have managed. Went from 5s to this setup and couldn't be happier. No sense at all the car even has modifications until u get into it.
298kw at all 4- 19psi, 98 octane, on a stinking hot day
tuned at GT auto garage
Unopened RB26
GT-SS turbos
1000cc injectors
Tomei cam gears
HKS SSQV
Tatech ecu
E85
403rwkw @ 1.5bar. I'm wondering why I get 1bar(14.5psi) only at 4800rpm. I've seen graphs where 1bar is achieved almost 1000 rpm's earlier. I had the same issue with std cam gears and now the same with altered timing. Any idea where the problem might be?
  • 3 weeks later...
  • 3 weeks later...
GTR33 Vspec
Untouched Block
GT2860R-5
Tomei Manifolds (wrapped in titanium)
Tomei Dumps (wrapped in titanium)
Tomei FPR
Tomei Adj Cam gears
HKS Fuel Rail
Bosch 2200cc
Apexi PFC
Greddy Hot Hard pipe kit
HKS Cold Hard pipe kit
Plazmaman 100mm IC
ARP Head Studs
CAMTECH 272/264 9.5mm
Performance Springs & Retainers
Blitz SBC @ 1.80bar
Z32 AFM
Splitfires
IRIWAY-8
Nismo Comp-C Clutch
Walbro 460 (single)
Complete Stainless Exhaust - Unknown Jap brand - 3inch down pipe to 3.5inch to 4inch rears (wrapped in titanium)
Venom 3.5inch Metal CAT 200CEL
Greddy Oil cooler/ Relo kit
KOYO Allum Radiator
JJR - Oil Catch Can
E85 - United
Stage 2 tune - 411 awkw / 551hp
Edited by GTR.80S
  • Like 3
  • 1 month later...
Garrett -9 turbos
Tomei dump pipes
Trust front pipes
Trust cat back
HKS cat
Partial intercooler pipe (from TT pipe to IC)
Nismo intake duct
Intake piping to stock air box
Tomei adjustable cam gears
Xspurt 1000cc
Walbro 450lph fuel pump with new bulkhead
Haltech platinum pro ECU
Zeitronix wideband sensor
Greddy spec-b EBC
Splitfire coilpacks
4 bar map sensor
325awkw @22psi
  • 4 weeks later...
1994 R32 GT-R
BLOCK
RB26
CP Forged Pistons 86.5mm
Eagle Rods
ACL Race Bearings
1.2mm Cometic Head Gasket Kit
Nismo Oil Pump
Tomei Oil Restrictor
HEAD
Ported and Polished
Bronze Valve Guides
Tomei Poncams Type B
Tomei Cam Gears
Standard Valve Springs
Standard Valves
COOLING
N1 Water Pump
Mishimoto Thermostat
Standard Intercooler
Standard Radiator
FUELING
FIC 850CC Injectors
Fuel Performance 320LPH Fuel Pump
Standard Fuel Pressure Regulator
MANAGEMENT
Apexi Power FC L-Jetro
Standard Airflow Meters
SPARK
Standard Coil Packs
NGK Iridiums Heat Range 7
TURBOS
Twin HKS 2540
EXHAUST
Standard Outlet Elbows
76mm Downpipes
Decat Straight Pipe
HKS Hi-Power Silent Exhaust
Did a quick road tune and did a power run the next day. Car made 371kw and 503Nm at the flywheel at 0.65bar boost on 45 litres of 95 PULP with 1 bottle NF Black.
Will be running an E50 mix and will tune for 1.4bar....post-133733-0-03605900-1441053075_thumb.jpg
  • Like 1
  • 2 months later...
95 R33 GTR
3.5" full system turbo back,
Forged built engine - CP Pistons & Spool Rods
Nismo AFM's
Delphi 900cc Injectors
HKS 272 Cams
Ported Head
HKS 1.5mm Head gasket
Garret 2860-5 Turbos
Apexi Power FC With hand controller
Tomei cam gears
Split Fire Coil Packs
ARP Bolts throughout
walbro 460 fuel pump
Tomei 1.5mm Block oil restrictor
HKS EVC-s boost controller
375hp @ 7458rpm ( 14psi )
463.6hp @ 6944rpm ( 23psi)
  • 3 weeks later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
