See this http://www.jwspeaker.com/blog/how-to-aim-headlights-driving-beam-or-high-beam-headlights/
From your second picture, seems like your passenger (left) side needs to go down, and your driver side (right) needs to move to the left.
But you really need to find a level ground with a wall.
  • Like 1
Thanks NiZmo Man!
  • 7 months later...
Any updates on this for the R32 Projectors?
niZmO_Man.... is the Mini D2S 4.0 still the one to go for?
I'm looking for something that will be relatively easy to fit (don't mind a little dremel work) and stealth as HID in NZ is a WOF fail.....
do elaborate the procedure >_< when you get a chance
20 hours ago, niZmO_Man said:
Diode on the high beam wire, so the current flows to the solenoid when you hit the highs.
The high beam bulbs on my car have a separate relay wiring, so I use the standard wires for activating the solenoid.
  • 5 months later...
I didn't take pictures of my dodgy wiring, but I'll make a neater harness so will take pictures then.
In the mean time, Morimoto D2S 3.0 projector with Osram CBI bulb, did a quick retro:
Try getting that with a H1 LED bulb :P
  • 3 months later...
  • 1 year later...
So, I have a set of projector headlights that I intend on retrofitting and then performing a transplant for the N1s.
I have read through a lot of posts about HID conversions and some date back a few years. Is the best option the latest Mini D2S and stick to 35w / 4200k? I.e. no point in going above 35w and I am not interested in bright white / blue headlights.
Looking at Lightwerkz, it seems like you can buy the brackets as mentioned above:
https://lightwerkz.net/collections/retrofit-brackets/products/nissan-r32-to-d2s-brackets
Then build your own kit:
https://lightwerkz.net/collections/universal-kits/products/bi-xenon-morimoto-mini-stage-iii-d2s-1
Cheers
Rob
Not sure why Lightwerkz didn't list it anymore, but they used to let you select D2S or G5 projector to go with their R32 bracket.  G5 is cheaper and has identical dimensions to D2S, except the housing isn't painted black.  D2S has a more centralized hot spot and G5 is more spread out, you can check it out on their comparison videos.
https://www.youtube.com/c/LightwerkzGlobal/search?query=g5
Thanks @TXSquirrel I will check it out.
BTW, it does mention G5 at the bottom of the page:
2x Nissan R32 to D2S 4.0 / G5 Conversion Brackets
  • 4 years later...
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
