Sigsputnik's Pix From Japan (regularly Updated)
Skyline GTR cigarette lighters. Not especially cheap either at AU$85ish a pop.
Proof that riced junk exists the world over. Note roof-mounted ski racks for superior handling.
Nissan Cima Calsonic Version.
RX7 with extra dials for go-fastness.
See y'all next time. :(
  • Replies 118
how farking pimp does the cima look? very nice indeeed.
and thanks to akkenan and dai oni for the settling the city/town dispute!! :D lucien, i believe that's on beer my way... :P
nice photos sputnik.
and thanks to akkenan and dai oni for the settling the city/town dispute!! :P lucien, i believe that's on beer my way... :D
I remain unconvinced. :D I can still picture the yellow sign in the train station as it was the most exciting thing in my life at the time (I spent a whole day walking around looking at Super Famicom and Neogeo consoles; ended up buying a some SNES games and bought the console later in the UK). Either way, I can probably cover a beer (long as its none of that pansy imported stuff) :)
Edit: Oh, and keep the pictures coming. Great stuff. I particularly enjoy the everyday sort of stuff (as weird as it sounds, the normal stuff is in someways the most interesting)
I remain unconvinced.  I can still picture the yellow sign in the train station as it was the most exciting thing in my life at the time
I used to pass through the station 2 times a day for a year and a half. thats a lot of times :P
I think those old Bluebirds are actually pretty quick when you do them up a bit. 2 ltr turbo u13 engine from memory with Atessa 4WD system. It may look ricey but I bet you it can move. Japan gets all the good shit.
yep you could be right but gee it looked like hell. but you'd have to really want a bluebird given the taxes on old cars and the giveaway prices on other cars in the second hand magazines (e.g. Car Sensor) here. :)
awesome man. i spent a year over there. (i actually bought my host familys stagea) as an exchange student. i lived in asakusabashi, which is the next station from Akihabara. some crazy cars there. found i had to head out of town a bit to catch some of the truer speed shops and garages. most of them are on the outskirts for some reason. saw some crazy street racing. genuine 11 and 12 sec cars, driven by 18-20 year olds, racing lambos and ferraris even. none of this "ill gun it in my commodore til i hit the speed limit" crap. these guys are crazy.
Suuupaa ekksutora speshyaru numba 1 fasto caaaru! if youve been there youll understand that.
Edited by qikstagea
yeah man these guys are serious, most of the time when they buy a fast car, they actually get out there and use on the odd occasion.
i guess cops in toyota crowns isnt much of a deterrent for them, hey?
roppongi is where its at - i worked in a club there for a while. (as a doorman, not a dancer).
Hi y'all,
More pix. :)
Even though this is one of the most ordered and recycling-aware places on the planet, there's also frankly quite a lot of garbage about the place. Things are good here right now, so people throw away lots of stuff. Here you can see flat screen tvs, fridges...
Even a pair of Bose 901s. They're still there day after day, slowly gathering silt and dirt.
An old arcade machine no longer wanted. Still had screen but no Jamma board (didn't check very closely).
R34 with diiiiiish.
Very nice Honda NSX
Now that's a bonnet vent. You could see the road through this thing.
No idea.
Hello Kitty is popular here. And worth $$$$$.
That's right, SPECIAL patrol.
Lowrider.
Darling would it be alright with you if I pimped the Rolls?
Titchy Smart Car.
See ya next time :P
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
