oh and manages13 my block and head machining has taken over 23 weeks alone (NO assembly at all) thanks to those involved
shit brad the company i have been using will offen do the same day drop off and pickup if i prebook a week or so out B)
DUDE that is one nice list i only cringe at what it must of cost to put together as i know how much it cost for me to get my build together. Can i ask who you are using for the build and tune? and when you might have it on the road?
pete
  • Replies 315
Thats definitely a dream setup.
Very nice pics.
With regards to the rb30det thing.. I think the biggest concern is the height. One big advantage of the 2.7 kits from japland.
But revability... Its got everything to do with gearing and how well the hotside flows. The VL's run a 3.45:1, run that in your Stagea and it too will feel like a big diesel. :(
Edited by Cubes
pete
tuning will be at Racetorque im 99% sure on. they mainly do race cars, and keep quiet in the performance scene in perth. been highly reccomended by another gtr owner with autronics and over 550rwhp.
the build is all done at home, machining hassles where through a few well respected perth shops but failed to show reliability and the shops told me 3 weeks for the block MAX and 2 weeks for head MAX. well im still waiting on the head which has been 12 weeks and the block was 11 weeks :angry:
PM me if u want the name of the shops i used for machining, as i dont want to upset the moderators :)
cost, hmm well im not gonna announce that here, bit over original budget though :lol:
should be in the car by xmas and run-in/tuned by end of january pretty definately. depending on the tuner :)
cheers
Brad
Is anyone else touching themselves looking at those pics?
Adrian
Yes i did...
Wow whats a setup i am jealous...
I think you have done the right thing with the 2.7 kit...
3 litre kits belong in R31's......
Hands down to you Brad, very nice job on your build - all top quality parts there. I'm sure you'll get power with reliability with all that gear.
Good luck with the build and keep us dated on the progress.
thanx guys, well im picking the head up tommorow finally, BUT it isnt assembled as i need shims for the valve springs, cause apparantly the JUN cams are regrind and have a smaller base circle.
so they aint even billet like HKS ones and are regrind from GTR cams. (thats the words of the shop doin the work).
so ive decided we will assemble the head as well, with the help of my uncle who usually does drag engines. shims will be arriving monday next week supposedly.
pretty pissed about the cams but, thought JUN was better than that? B)
does smaller base circle mean they are not as good in making power as a set of hks normal base circle size ones with same degrees and lift?
cheers
Brad
They weren't able to machine up shims?!?!?
The reason for the smaller base circle is to allow for a higher lift without or with very little head modification.
Tomei also uses this method to squeeze out a little more lift.
Edited by Cubes
no they said the largest shims they had were not big enough and they needed "special" ones made or some shit. sounds like an excuse to charge a shit load of $$$ for f**k all :) gotta be custom made and specially heat treated or something they said.
i took the head off the shop cause they have had it 13-14 weeks to do porting and reassemble, so they ported it and wait till now to check the cams and whether shims r needed and now they delay it another week, plus assembly time. so i told em to not bother and i will do it.
Dont mean to burst your bubble but make sure you get it tuned by a reputable tuner. We tuned a 500hp built 930 Porche TT over here on the Gold Coast. It had been tuned by some guru in Perth that used all of about 5 of 200 available features of an autronic. The car was that rich that it had washed the bores!!!!
I was going to say give Greg at proengines a call about shims, he reshimmed my head and it was a pain in the ass but he got it spot on, with no bullshit. He has posted above me though, so thats obviously where he got the shims from ;)
cheers
Brad
Hi Brad, all of the Jun cams I have seen are billets. They have to use a smaller base circle to get the lift, RB cylinder heads don't have enough room. The Jun instructions and web site both quote the following for all lifts over 10.5 mm;
Clearance of head for cam lobe rotation required.
Special valve spring required.
Special valve retainer required.
The "Special valve retainer required" means the cam has a different (ie; smaller) base circle to standard.
:) cheers :D
There seems to be a few people that are having trouble with machine work being done on their engines, either they are very slow or not done correctly.
Greg at Proengines posts here on the SAU and the work he has done for me has been nothing but exceptional and in a timely fashion. Won't go anywhere else now.
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the 2025 build re003s’ on my 06 XT Forester Turbo and I quite rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
