Guys,
With the heat coming/already here, i decided to get my AC converted from R12 to R134A and gassed up, the guy who did it did such a good job i organised a group buy for SAU members.
Group buy start date: 1st January 2006 (not far away)
Group buy end date : 1st April 2006
Location: When you book with Phil he will give you a location around the Bass Hill area
What you get: COLD AIR!!!! - New receiver/dryer, new R134A gas, new rubber seals on the whole system. Basically everything you need. Plus warranty.
Price: $220 inc GST (take cash, no ATM's close by)
To book: Call Phil on 0418 608 680 and mention you are calling about the skylines group buy, he will give you a time and date
(If you can get this conversion done cheaper then great go for it, dont post here)
(Mods if i forgot anything please pm me and ill change/add - thanks)
https://www.sau.com.au/forums/topic/98646-sydney-air-conditioning-group-buy/
  • Replies 49
Posted Images
well the old R12 gas is actually better for cooling, but most old skylines (more than say 10 yo) have had gas leak out, or even had it let out before leaving japan. now as R12 is very harmfull to the environment it's illegal to regas R12 systems. they must be law be converted to R134a. when the system is chock full of r12 it should be able to get so cold as to be almost unbearable, even in summer. if it's not that good then it may be time to go the conversion.
Yeah im sure a receipt can be provided if requested
dOOds, its worth it, i can usually put up with a lot of cold (skiing in board shorts for example) but it gets so cold in the skyline now i dont use over 75% force from the ac, and phil does a really good job
Baron is correct, its illegal to regas r12 (even if you can find it someone with it) so the conversion is cheaper in the long run and more comfortable :D
Question, my car is allready converted to R134a but I think needs a service and regas. I'm guessing that it's still possible to get this even though it's allready R134a.?
Cheers.
how can u tell if its R12 or R134?
generally its just by the type of inlet that goes into the tank.
The older R12 setup has a threaded top and the newer R134a has a quick release valve.
Take your car to the local AC joint and they can steer you in the right direction or take a photo and post it up and can answer it for ya :rofl:
Cheers B
I'm assuming that R34s would be using the new system and would only require a re-gas? At the moment, 18 degrees sure as hell does not feel like 18; more like 23-25!
Hey Stan, you could have a problem with the 'thermistor' in the air handling unit under the dash. This tells the climate control module when to cut the a/c pump in and out. Although your car being an R34, its unlikely to be faulty unless someones fiddled with it at some stage. But like they say- weird sh#t happens. My 32 GT-R was gas converted at the same place as Steves and Phil found out someone had put the temperature reader (thermistor) in the wrong place at some stage, and it was faulty, so he wired in a Falcon (yuk!) thermistor as a temporary fix (18C in mine feels more like 13!), it will need to be re-gassed again after the new Nissan sensor is fitted, but Phil won't charge for the gas again. He's a good guy.
Steve.Have you got any pics of the new system.
EDIT:Ive just got off the phone with steves aircon man and been informed that seen as though i have have had the system apart before hand for more than a day,It needs a new filter and full regass.
It's going to cost me $154.00 all up.
He is slightly cheaper priced compared to others out there.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
