It wasn't me. The HICAS did it. :rofl:
It appears that the only damage that will require $$ is the rear bumper. The skirts need to be re-fitted and a bit of polish should sort out the rest.
For anyone that is interested, the data logger has confirmed that Michelin Pilot Sports max out at about 1.1g. :D
Edited by clayoth
  • Replies 160
Posted Images
Budge I hear you mate, and I bet there are few who put their hands up for commitee jobs because of it. Tell you what, ditch 'em and come join us, just leave the Superman suit behind.
What don't you need to have a Skyline to join the club? else why call it Skyline Club, may as well call it Wang Club or something like that.
I can help there Clayton, still have 2 R33/34 kits reserved for Wangers only but as I suggested, the brake balance may be the culprit....
Get matched rear calipers and master cylinder and sell the old calipers to Matt (R34GTT) and both of you will then have good matched brakes. ABS can cover a lot but not all the issues of mismatched brakes.
No you don't need a 'line to join, just a certain appreciation...right guys???
C'mon Budge, tell 'em........... to get stuffed and bring the good ones too :D
All those pics and not even 1 of my car :)
LOL...now you kjow my pain. No one ever takes pics of the R32 :O
Though i thought with all the bling on your car there would ba a few photos. Then again, balck car, night, maybe they just didnbt turn out
..oh and found the car i need to buy for this years Mod RWD class :(26gtstengine.jpg
Its an R33 but i think i can make an exception and own this GTST :)
I'd like this pic the best  :wub:
Pic
managed to keep the fire breathing Godzilla behind until half way down the straight
Hahaha - nice photo Hung.
Keeping Jack behind you and all with only 3 wheels on the ground!!!
This ones pretty good too. Pic
Hi, yeah that's my car - first time I've had it on the track.
Was very happy with the day as nothing broke or fell off.
It's a heavy dunger though - I still have 2 secs to find to get down to my Sti times.. :)
Cheers
Andrew
Very impressive, just wondering how long the rear bumper bar will last with all the flame throwing actions.  <_<
Will have to ask Geoff!!!! He's an expert at flame throwing......
It's a heavy dunger though - I still have 2 secs to find to get down to my Sti times..  :unsure:
Cheers
Andrew
Good stuff Andrew, looked like you were having fun, oh and don't worry, TEH GTR CAN NEVA LOSE! (except when driving in motorkhanas, especially blue R34GTR's.... :) )
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
