  • 3 weeks later...
Manual R32 RB20DET
With
POD, FMIC, 3" Turbo back exhaust, empty Cat
on 11psi running on 95 octane (dont ask) got 140RWKW
Since then added
RB25 Turbo, RB26 Injectors, Nistune, cheap 3" Cat (to be legal)
And on 15psi running on 98 octane got 190RWKW
Yes tune needs a touch up but I'm happy with the results
considering how stock the engine is and how small the turbo is
  • 4 weeks later...
R32 GTS-T 1993-- Before i bought it 200.7 rwkw @16 psi
Since ive got it
Internally stock rb20det rebuilt at some stage to oem 130,000kz
z32 afm , pod filter
X force 3 inch exhaust whole way , catco highflow cat , 4 inch rocket tip
Remapped rb20 comp no rev limmiter revs past 9k , no boost limmiter
Rb25 turbo rear housing bored out , bigger rear steel exhaust wheel , recently bigger front housing and different bigger steel wheel
555cc injectors and bosche 044 fuel pump braided lines ect
adjustable cam gears
custom 80mm throttle body
Really neat FMIC huge for a r32 ,, engine bay detailed and neatened up
running boost T manual tap atm because have to go through regency running 15.5 PSI Very safe tune according to air fuel ratio
ran 235rwkw on 15.5 pound will make more with electronic boost controller...
""Future mods , poncams ,rb30 bottom end , forged pistons 22psi!!! 300+rwkw
Edited by dato$2nv
About time i put up my results..
R32 rb20det with 165k km's now
FMIC
Hypergear TR43
Z32 afm
Gtr injectors
X-force 3" dump/front pipe & High flow cat
3" cat back
Std airbox with small cai
Adj. cam gears
Walbro fuel pump
Dr Drift remap
215rwkw @ 16psi
RB20DET
standard Internals
177,000+Kms
272hp atw @1.2k boost
MODS:
Apexi Power FC
HKS 2535
External Wastegate 45mm? I should have measured it...
550 Denso injectors
Z32 AFM
Old style BLITZ? FMIC
Bosch pump
3in from turbo, hi flow(ed) cat
just got the car.
loosing boost at top end due to cheap bleed valve.
Im measuring 550km on one tank (40L) with highway driving. 350km for city driving...
Thanks to the guys at Hyperdrive!
Retuned the motor last week at AllStars in Malaga.
Made 295whp @18 psi, 1.3 bar, pretty happy with that. made 20 odd hp across the board too.
the car felt better even from the carpark.
Changes made was,
Rb25 intake pipe before the throttle (bigger than 20) -$free
New pipe was made from the afm to turbo, made from truck intercooler piping (spools faster and makes impressive suction noise)-$free
Bosch 044 -$100 lucky score
2.5m longer vacum line to waste gate, open little later -$5
Cleaned air cleaner pod -$free
Cleaned intercooler core -$free
Leak free Bov!
and other air leaks fixed.
Run on 98ron fuel.
hey guys just got my r32 tuned with awesome results.
-balanced bottom end
-ceremic coated pistons
-1.2mm apexi head gasket
-ported head
-adjustable cam gears
-bosch fuel pump
-denso 550cc injectors
-z32 afm
-stainless lowmount manifold
-kkr480 turbo (modified)
-full 3" exhaust with custom dump pipe/front pipe
-custom intercooler and piping
-new eprom and tune by vonnie @ dyno tunz @ browns plains, qld
-turbosmart e-boost street
car made 227kw/304hp @ 19psi
  • 5 weeks later...
-RB20DET / Stock internals
-HKS 2540 ball bearing turbo
-Cast exhaust manifold
-38mm turbonectics wastegate
-Link plus ECU
-370cc injectors
-Bosch 040 fuel pump
-Splitfire coils
-GTR intercooler
-3" exhaust
-Greddy bov
-Malpassi Fuel Reg
-80mm throttle body
-Oil cooler
-Alloy Pully kit
170kw at the wheels on 14psi on dyno dynamics dyno, tuned by mike at diesal and turbo,
got hks 264 9.0mm cams still to put in, also looking at a GT3040 turbo, then a retune on 18psi :P
Edited by NMSIS
  • 1 month later...
Hey. RB20 in my R31 wagon
Greddy 600x450x76 cooler
RB25 hiflow Turbo
Bosch 040 pump
Apexi pod
3inch Exhaust With Hi Flow Cat
Bleed valve
additional shit to consider..
Stock injectors.
10:1 AFR
No oxygen sensor.
Timing 10 degrees out.
160.34kw @ 12psi 10:1 AFR.
This is a Chip that we have developed for DSR430-RB20DET using Standard Internals, Injectors, regulator.
Only Modifications were, DSR430 G2 Turbo, Walbro pump, front mount intercooler and Tune.
http://www.d1nz.co.nz
http://www.jdmperformance.com.au/
Edited by dsrturbo
Standard RB20DET
HKS2530
GTR Injectors
Bosch 040 Fuel Pump
Z32 AFM
CoolingPro Intercooler
175-180rwkw at 14psi with slight misfire.
Getting retuned at 18psi once I have unfouled plugs and some Splitfire coils.
Got it tuned to today at 18psi with yellow jacket coilpacks.
Would only spike to 18psi and trail off to about 16psi.
Got 210rwkw, had a really bad batch of fuel though. Had to knock heaps of timing off compared to last tune and even then its pinging, siphoning the tank tonight and getting some better stuff.
Just so everyone knows only buy Synergy 8000 from Mobil, don't buy the '98' that some of them are selling as it seems to be completely different.
r32 gts-t rb20. internally stock.
garret gt2876r, gtr injectors, z32, bosch 040, full 3inch exhaust, greddy fmic, 3a pod filter, dr drift remap, powwwa 225kw
dont have dyno papers yet but was really happy with the results going back again to install cam gears...thanks to sam at dr drift great guy.
  • 3 weeks later...
1990 Nissan Skyline GTS-T R32
1480000km
Internally Stock motor
Split style stainless dump pipe
3" exhaust decat
RB25 turbo @ 13.5psi
NPC 5 puk clutch
Pod filter
500hp walbro internal fuel pump
cooling pro Fmic
greddy catch can
oil cooler and oil filter relocation kit
That dyno chart is not quite a full run as the car was having trouble at the time with boost and a misunderstanding with the mechanic thinking it was running 28 psi when infact it was only running 14. so he backed off in the top end.
The car has since been fitted with a std series 2 rb25 turbo and seems alot more responsive and angry up high. I am just waiting to get a fuel pressure reg and I will get her back on the dyno.
  • 1 month later...
95 240sx
Ford Lightning MAF blow through, Tomei 270 cams, Tomei valve springs, Tomei headgasket, Rips intake manifold, Protech-fabrication turbo manifold, Stainless 02 housing made by Protech-fabrication, Precession SC61 turbo, Tail 40mm gate, Sard 800cc injectors, Supra TT fuel pump, Nistune Type 2 board, HKS EVC 4 (not hooked up at the time)
398Hp @ 16.8psi Couldn't get my nistune to listen to me :blink: so basically it was set for the injectors and maf on the stock map. Ran really rich then started to go lean up top so I'm going to rewire the fuel pump for next time. If I can get control of my map I'm sure I can hit over 400hp at the same boost levels. Pump gas used for the runs.
Edited by BlueRB240
RB22 - 370rwhp 481nm at 18.5 did a run at 20.5psi 388rwhp and 505 nm
but will keep it safe for now and still only running std rb20 g box
5000 rpm peak hp 5750 rpm peak nm.
revs right through to 8000 rpm holding 355 rwhp to end with 17psi on drop off
HKS 2835 GT Pro 0.82
HKS 264 in /ex cams
HKS adj cam gears
ARIAS custom forged pistons and rings
HKS head gasket
ACL competition bearings
New springs
balanced, blueprinted internals
rb 25 crankshaft, rb26 GTR CONRODS
GTR Injectors
Nistune
Greddy FMIC
K & N pod filter
Splitfire coilpacks
Z32 AFM
race ported head
gates race belt, tensioners etc.
Custom extra capacity sump
Oil restrictors in head
Massive Oil return from head to sump
Crank Collar
Custom Baffled catch can setup with full oil return to sump
Greddy Oil cooler with relocation kit
Exedy Single Plate 5 puk clutch
Walbro fuel pump
3" straight through with 5/6" cannon muffler
Manual Turbosmart Boost T
A touch laggy but mainly using as drift car at Barbagello so a track specific setup anything or anywhere else would use same turbo 0.63 rear or 3071r with 0.63 rear housing or Trust TD06g for little more response
alot of time etc spent on oil system to get that right and up to standard for harshest conditions
Am pretty happy with the setup .. has 400hp in it may go there if put a 25 g box in it... only really want to add a Plazaman plenum to shorten cooler piping and possibly increase response and mid range a touch and a 6boost just because
  • 3 weeks later...
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
