A small update on mine.
I have changed from a borg warner s360sx to a s362sxe using the same exhaust housing and everything else the same.
Due to fuel pressure issues we only did one run over 20psi which is below. This is on very soft timing and once fuel issues are sorted it will do over 500kws
  • Like 2
  • 4 weeks later...
Finally got around to installing some 1650cc injectors and C125 dash, plus a quick retune - quick because it was 38'c in the workshop and intake temperature wasn't conducive to tuning and power runs.
Having said that, it surprised me how well it performed in the oppressive heat. We did a run at 29psi (564+) and a run at 31psi (578) It gained 7kW/psi. We commenced a third run at 33psi but it popped a cooler clamp. New clamps fitted ready for another session early in the new year. I think 595-600+rwkw at 33-34psi is realistic.
  • Like 3
  • 11 months later...
Recently jumped ship from an internally stock RB25 as she was about to grenade herself.
New specs:
S2 RB25 head fully refreshed. New OEM lifters, 268/272 9mm camtech cams, welded and mated to a RB30 block and external VCT oil line.
RB26 ITB setup with brand new OEM throttles and adaptor plate mated to the head. Controversial to what people bang on about these adaptors, I have never had a issue nor one leak.
Forged RB30 block. CP flattop pistons, h beam rods, ACL race bearings, N1 pumps, OEM balancer, larger sump.
Gen II GTX3582r .82 with a 50mm pro gate welded onto the housing. Hyper tune 600 x 330 x100 cooler, 3 inch exhaust with waste gate plumbed back in.
1000cc injectors, 044 external pump running of the surge with a in tank denso
Link storm ecu with a bunch of sensors monitoring the engines vitals.
Plenty more I have missed, but you get the idea.
E85 made a maximum of 363kw but the Link kicked in fuel cut as we didn't have enough fuel to feed the engine. Detuned to the same as 98 at 340kw.
Larger fuel pump/s and possibly injectors and I'll go again. For now I am going to enjoy it for what it is!
  • Like 1
Hey guys little update, its been a while, After playing with no vct using the s0 rb25de head i have now changed to rb25 s1 vct head and have kept vct using the external feed, only changes to the setup is the head and a larger gate.
Little run down on what it has now,
Bottom end:
Stock rotating assembly, stock rods, stock pistons, stock crank with rings and bearings and using arp hardware.
Head:
S1 rb25, stock cams, kelford springs, slighty ported exhaust ports, 1.3mm cometic gasket with arp studs.
Inlet:
Freddy plenum, cleaned up the castings as it looked like aids on the inside, 80mm chinga throttle body.
Exhaust side:
6boost high mount with 60mm turbosmart gate, hypergear atr45ss 6x6 (12 blade) billet compressor wheel with .82 rear, full 3 and a half inch stainless all the way from turbo to rear with a cat and medium size ressy.
Ecu:
Haltech v1 platinum pro plug and play with wb1 and flex sensor
Fuel:
1000cc bosch injectors, stock metal hard lines with standard size rubber hose, single walbro 460 in tank pump, turbo smart 1200 fuel pressure reg with race works rail.
Probably missed a few things but most should be covered.
Ended up with 340kw on 98 and 415kw on e85 at 21-22psi, old head made 370kw on 98 but was at 25psi, now with vct and the wider power band we calculated that the 340kw with the vct and that it comes on earlier versus 370kw before hand its actually the same average power over all which was interesting.
Now have kelford vct 262/272 9.35 lift cams in and some 1600cc injectors to go in so will see what it will take on stock fuel lines and see how far the pump will go. 20180507_210943.thumb.jpg.e0612d8de8d66cc0fd4111571ad7e2bf.jpg20180327_225537.thumb.jpg.326faa372ffc38201c38c29e2f7b27a2.jpg20200603_142508.thumb.jpg.87c976ecbf6f74068843ecdfb36f8873.jpg20200419_115621.thumb.jpg.fac8f95ddc69e5e7c433aebe42ddd45d.jpg
  • Like 3
  • 1 year later...
another small update, still on 20psi due to running out of fuel pump. we fixed the pressure issue. but now have run out of pump.
  • Like 2
  • 4 weeks later...
R32 GTR...
RIPS built RB30 with Nitto 3.2 Stroker kit
RIPS Billet block brace + main caps
RIPS Extended sump with baffles
Tomei Oil Pump
RIPS Catch-can
Horsepowerheads drag spec RB26 head - CNC'd and fully built head with 286/278 cams
The entire Kelfords catalogue was thrown in the head.
Nitto head drain kit
Greddy 4 inch Intake
6Boost Exhaust manifold
EFR9180 1.05 Turbo
4 inch Titanium full exhaust system
Hypertune Gen2 intercooler
PRP Crank/Cam trigger kit
PRP R35 Coil kit
PRP AC Bracket
PRP Alternator bracket
OS Giken R3C
CWC Alternator kit
TurboSmart Pro 60mm Wastegate
TurboSmart FPR 2000
TurboSmart turbo Oil pressure regulator
TurboSmart EFR Blow off valve
-10 Fuel feed
-8 Fuel return
Frenchy's performance twin intank kit
2x Walbro Hellcat fuel pumps
Aeromotive PWM fuel pump controller
Pretty sure there's other bits n pieces I've missed out. Churned out a very conservative 360awkw on a 4wd roller dyno. Rev limit is only 7.5. No timing etc in the tune. Purely tuned to conserve the stock box, peak boost of aroun 13psi.
I've ordered an Albins kit from PRP, however its taken Albins just over 1.5 years and I still don't have the box as they keep f**king me around
Once the box is on, I've got an Alpha Omega 1 piece shaft as well, along with other bits, and will turn the wick up.
Still more to go.. Looong list of crap that needs doing.
IMG_9157.thumb.PNG.ce28a45561d82a32b59f082f941976ec.PNGIMG_8002.thumb.PNG.f4ea0ce4f501bc21d97e12e8ad47416e.PNG
Edited by Predator1
Added pics
  • Like 3
  • 1 year later...
Update on my Rb2530det R33 GTST sleeper build
Engine Specs:
Rb25det head with forged Rb30det bottom
Forged pistons and con-rod
Upgraded Valve springs
HKS 256/ 264 drop in cams
Fuel system:
1650cc Bosch fuel injectors
Two 460L fuel pumps
ECU:
Haltech ECU
Turbo side:
Hypergear ATR43SS-3 ProR Turbocharger
6 boost high mount TS exhaust manifold
Turbosmart 50mm external gates
Hub Dyno Tune: Chequeredtuning Victoria
Car made a responsive 497rwkws @ 25psi full boost by 3500RPM. Hitting 150rwkws @ 3000RPM and 340rwkws @ 4000RPM, with wide spread of power band and plenty of area under curve.
Edited by hypergear
  • Like 2
  • 3 weeks later...
R33’s back on the dyno with another of HyperGear in-house built specials. No other changes made apart from the turbocharger, we managed to get:
516rwkws @ 26psi
569rwkws @ 29psi
606rwkws @ 30psi
642rwkws @ 34psi
Dyno Video:
  • Like 5
  • 10 months later...
  • 2 months later...
another update on mine.
got fuel issues sorted and maxed out the turbo on a mainline hub dyno:
Final results are 420kw @ hubs @ 18psi on 98RON, and 500kw @ hubs @ 23psi on E85, with full boost hit by ~3700rpm (but for 20psi and above we roll the boost in to be nice to the rods)
Specs:
Rb30 block
Tomei 256 poncams
CP pistons 8.75:1 compression
MRP rods
ARP rod bolts, main studs, head studs
Stock crank
RB25 oil pump
RB25 head
Vct enabled
Kelford valve springs
Home ported
Vipec i88
NZ wiring cam trigger kit
Greddy intake manifold
Sinco twin scroll t4 manifold
Borg Warner S361SX-E Turbo
Precision 66mm wastegate
Twin 3-port MAC valves for boost control
1550 xspurt injectors
Twin In-tank Walbro 460lph fuel pumps (staged)
Ethanol content sensor
Custom 4" exhaust
Edited by Looney_Head
  • Like 4
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
