wouldn't i go for bkr7es (or bcpr7es) for the colder plug? or am i getting confused?
Black soot would indicate a hotter plug is needed but you might not need to change the plug if gapping it down does the trick.
ahh yep i get it, so the plug is hotter to help burn off the soot, or another way, so its not a cool area in the cylinder for the soot to form on...
That is a dangerous game to play. I would say your plugs are sooty for different reasons, most likely just rich A/F ratios the car could be R & R'ing or could just have a rich idle (bung O2 sensor) or just be a normal rich running RB with upped boost.
If your car is in any way modified, I wouldn't recommend hotter plugs; standard 6's would be a minimum.
Edited by SKiT_R31
just changed my ngk coppers (bkr6es-11's) to bosch fr7dp's (equivalent to ngk platinums gapped at 0.8) and the car is now drivable again. the coppers died after 5000km and on the day i changed plugs the car was barely drivable. was very sad.
still missing problems every now and then but that'll be the coilpacks, they're desperate for a change
  • 1 month later...
I have standard copper BCPR6ES and the car misses a few beats at idle.
At higher rpms I could not detect anything unusual.
(running 14PSI)
Is it normal that the car misses a few fires at idle?
RB25DET
Thanks and sorry for being slightly off topic.
Cheers,
Andrew
(running 14PSI)
if you're really keen to make it a bit smoother do a search, it's a pretty common problem but most people just leave it. first things to do are clean the iac and aac valves, there are diy's on them in the diy section...
but as said above, it's pretty normal
miss at idle is usually the ignitor getting tired, pretty common
Thanks guys .. I was a bit worried about the pops at low idle.
And to contribute something to this thread:
I am using these V-Line Spark plugs in my Skyline (on the right)
VLine
NGK on V-Line
I have no idea if there is any advantage to multi electrodes, but on my motorcycle it really made a difference.
(though I don't believe in Snake-Oil :verymad:)
And here's a link from NGK with some videos included (technical advice on installation):
NGK
More:
Edited by Torques
i've had a miss fire problem for months and just assumed coilpacks. hadn't even thought to change plugs. i'll just go copper so that's BCPR6ES right? RB20 running 7 PSI?i drive fairly tame 70% of the time. i bring it up on full boost probably only once or twice every drive. so that means i should go a hotter plug? or doesn't it really matter and i should just get the bcpr6es?
go bcpr6es-11's cos it's stock boost. 6 is a hotter plug, 5 is recommended. have a read of earlier pages in this thread, plenty of answers there
After finally getting my FMIC return flow installed, it took me awhile to narrow down this thing my car is now doing. If you've ever had or driven a front wheel drive car with maybe old or spongy front shocks, you'd know the feeling when you are trying to floor it and hit bumps. The car kind of shudders a little and you can feel the traction slipping.
Now with my car I have a standard turbo running the ground boosting trick. What happens is when I put my foot down, there is for sure more power there, but there's also this feeling like the car is slipping or hiccuping. Could this be due to my Bosch Plats being gapped at 1.1?
I don't know where to start to go about fixing my problem, but at first I thought I was just imaging it, but after driving around more it's there for sure. Oddly I notice it more than I have the Overdrive ON. When it's OFF and I have the Power/Snow switch set to Power it still does it, but I think the increase in revs is helping to hide the fact I've got a problem somewhere.
So guys, where do I start to look at this problem?
5 is a hotter plug, 6 is reccomended. 7 Is a colder plug and is more ideal if running more than stock boost imo. Also, a 1.1 gap is fine providing your coilpacks are in good shape, but 0.8 are what your supposed to run and will give you the least issues (especially if your coilpacks are getting old).
It's common for a missfire to clear in the higher revs, its definitely your gap, i would down it to 0.8. If you still have issues you need to source some new coil packs - you can happily gap down to ~ 0.6 but any lower and you start to really hurt your idle and light throttle/off boost.
Ah ok. I still have my old Autolite plugs, so might clean them up, gap them to 0.8 and see if that cures anything. If it does, then I'll have a go at gapping the Bosch Plats. I don't want to damage them if it turns out it's not the gap, so the Autolites will be testers hehe.
bosch plats gapped at 0.8 are like $5 more than the 1.1's, well worth the dollars cos u dont have to risk damaging them
Where can you buy them from? I got mine from Repco or something for a 6 pack @ $38 or something. They only had the 1.1 gapped ones.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
