In Melbourne I do it, in Adelaide Martin Donnan, In Perth Speedworks with Badbiki. And there's the fact that Badbiki and PLMS both sell rom editing boards for DIY.
My contact is [email protected] 0425 818 755
More than happy to send any QLD enquiries your way, and perhaps you could return the favour....
Remapping is certainly a far better option than E-Manage.
Sam.
  • Replies 234
And Mark at Hills Motorsport in Sydney also remaps standard computers, and Powerplay also in Sydney sell remaps done in jp by a ex-nismo engineer.
Plenty of choices, and a remapped standard computer is a great thing. We run them in our race cars, we get to keep the knock sensor and consult ports among other things ;)
I work for chiptorque down at the coast.  I would suggest you bring it there as we are the only people in Aus that can reprogram the factory ECU as far as I am aware.  Tell me more about it so I can give you the approximate gains.
A few mods are in my spare room at the moment but they will be before I get it tuned.
Redtop sr20det 180sx auto,
GTi-R t28, full exhaust, pod, stainless exhaust manifold, FMIC, boost controller, walbro.
I have 550cc injectors (top mount + rail + FPR) to go in, and would get a bigger AFM if recomended.
I looked at chiptorque's pricing a while back, and it was significantlymore expensive than an e-Manage($400) + tune ($200), are the prices on the website are still current and un-flexible?
I'm a cheap bastard you see.
Would definately suggest bigger AFM (z32 are good) as the standard airflow meters usually restrict power to around 160 - 170rwkw somtimes you can get more. With those mods your probly looking at around 200rwkw. This is a rough estimate. Hmmm sard injectors not my favorite to tune but they are ok. I will find out a definate price for you. You might have some time to save as our booking period is about 3 weeks in advance at the moment but we'll see what happens. You cant really compare the E-manage to a re-mapped ECU, talk to any of the guys in the know.
I am chasing around realistically 200rwkW (optimistically 210-220), so the AFM will be obtained for install at the same time.
The injectors are Denso (which I think are made by Sard anyway?), and I got the set of 4, top mount rail and malpassi adjustable FPR with guage for $350 the lot. :) Told you I was cheap.
I have a few questions (starting to get off topic, but I'll press on anyway): Are the maps preset One-size-fits-all, or is each car tuned on a dyno? Also I will be getting a high stall/transcooler/shift kit down the track, will the ECU need to be re-tuned to accommodate?
The price for the ca18det is a lot more appealing @ $600, comparable to the e-Manage + dyno time, why is the sr20det package one and a half times the price @ $900?
Also the chiptorque website is a bit thin on technical information, and what exactly is done to the ECU, whereas I know exactly what features the e-Manage will provide. Can you explain it in detail what functions of the ECU are adjusted?
Sam - Sounds like you've got much the same gear as us. Yeh we can do the r33 25 however we need to get the boards in from Japan. The focus of the company is more aimed at ford and holdens however we can tune anything really, we've recently had a couple of 360 Modena's in lately very nice. It just depends these days where you want to specialise I guess. The other thing is budget, if you could afford to R&D every car to the level that we wanted we would most definately be out of business. I'm sure you find yourself in the same predicament.
Hi there,
I just got the e-manage in my R33 skyline II (rb25det).The car running very bad and I couldn't tune it.Could you give me some idea please? Or tell me where can I go fix this problem please.
Thank you
What harnesses are you running....ignition, injection, boost?
If it's hooked up the ignition harness without using the diode trick, then your coils are probably already starting to get damaged.
Hi man
I just got an E-manage on a RB25DET .It running so terrible.I think it has the problem as what you show.And I don't know how to tune it.Could you show me the way how to fix this problem?Please?Now the car can't even run on the street.
Help please
Jack from melbourne
[email protected]
First step is to check that all the internal dial settings are correct, the 5 screw adjustments are set to 0 and it is wired up correctly.
If there is a problem with wiring or the dials it should be flashing error codes at you.
Plugging the unit in with everything set correctly and 0 correction will have no effect on the running of the car. I have wired up 3 engines, rb20, rb25 and ca18 with no problems on start up.
Hi man,It's me again
Thank you for your reply.
I already have a quick check on the ECU there.The connetion and the setting is corret.And I set it to all 0 it comes up the sam thing.The RPM very low and no power run at all.
Please give me more opinions or show me where can I find someone to tune it.
Thanks
Jack
Thanks
Jack
Jack,
Your best bet is to ring around the tuners in your city until you find someone who has tuned an Emanage before or is willing to have a crack at it.
Hey I'm in the process of looking at getting some bigger injectors to get fitted along with an Emanage and was wondering which ones are the best to use? Sard make 550cc injectors, Nismo and HKS make 555cc injectors. 555cc is right on the limit of the 150% increase over the stock 370cc injectors that the Emanage/rb engine can handle so would they still be OK? By the way my engine is an RB25DET and it's also an auto.
How much power are you targetting? If under 500 bhp, then SR20DET JDM manual injectors are worth considering.:D
With the e-manage it's the fact that the ECU adjusts the AFM voltage to 'trick' the ECU into providing less duty cycle to the injectors, the down side of this is the fact the ECU also thinks the car is under less load and as a result is using a load point on the factory MAP that has a lot more timing advance than normal. The bigger the injector size, the more timing the ECU advances, until a point where the advance is just too much for boost/load conditions.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
