What exactly would I ask for and where in Perth can I get some of this heat strapping style insulation? Who makes the best VALUE stuff... and would it be suitable for keeping the cooler pipe (outlet side) cold as it runs over the radiator due to the cursed RB30 Plenum setup.
Cheers,
Brent.
Yer Brent i'm looking at doing that to coz after a few mins idling that pipe gets heat soaked from the motor.My cousin used that exhaust wrap stuff but have'nt found out how it goes yet.
You can buy the exhaust heat wrap in coils from any decent car parts place, but it is horribly expensive for what it is SURPRISE !
Or you can get better stuff cheaper in a wider variety of sizes, but you have to hunt for it. It is called "fiberglass furnace tape" and it is used as a sort of gasket material and pipe wrapping for boilers, furnaces, kilns, pizza ovens and so on. It comes in rope or tape. The rope is used mainly for door seals, but the tape comes in a very wide range of widths and thicknesses. It looks a bit like fiberglass matting.
Look in the yellow pages under furnace repairs, or something like that.
For heat insulating intercooler pipes and induction systems, I have found black sponge neoprene sheet is easier to use, and looks a lot better. It is the same stuff they make wet suits out of, and makes superb pipe insulation. It stretches, and you glue it straight onto the pipework with contact adhesive like "quick grip". Petrol washes off any glue that ends up where it should not be.
This neoprene wraps around sharp bends easily and neatly, and looks good in the engine compartment. Clark Rubber shops have it in various thicknesses. It is expensive if you buy yards of it, but you probably will not end up needing much.
As a reference I got my tubular manifold HPC coated for $120 ea... but thats cos I had 3 of them done at the same time. If you want pics, i'll post!
But yeah I wouldnt wrap the exhaust manifold. Thats asking for trouble.
I was going to do it over the next few weekends, why is it not a good idea.
I thought that it was the rapid changes in temperature that causes the manifold to crack, not the actual temp that it runs at. With less extreme cyclic temps i was thinking that in conjunction with my existing HPC coating it was going to help manifold durability as well as under bonnet temps
I've been contemplating the heat wrap as well, as my IC piping doesn't seem to be the most efficient at dissipating heat.
How do some of these prices fare compared to those who have purchased elsewhere...
http://stores.ebay.com.au/autoFlash-Store_...displayZ2QQtZkm
The I/C pipes are not there to dissipate heat.
That is your I/C job :)
You might get a bit of heatsoak through the pipes, but seriously, if your running 14psi... from cooler outlet --> plenum you aint gonna be picking up massive amounts of heat through the piping.
Maybe a few degress is anything.
The reason its not a good idea to wrap turbo manifolds is because you are trapping all the heat in the metal. Aftermarket turbo manifolds already run real hot and are fragile. Wrapping them is making your risk of cracking one alot higher. (Im not sure how you are going to wrap a cast item anyway, but they are more sturdy)
Most places say dont even heat wrap your dump. The metal eventually crystallises and becomes very weak, altho mine is wrapped for a year now, its startin to look a bit odd I have to admit. I dont care if it busts cos Im going to replace it anyway.. Check this out;
http://www.centuryperformance.com/heatwraps.asp
Altho that applies to headers, its very good information. Its no coincidence that using heat wrap voids warranty from virtually all header manufacters.
Cant you buy ceramic coat in a can?im sure ive seen it advertised somewhere.It would a good alternative to getting a shop to do it.Has anyone done this?
ive heard about the heat wraping the dump pipe thing.Its got somthing to do with condensation after use being trapped in between the tape and the dump.It s;owly kills the metal.Their suggestion was to coat it with a coat of ceramic of heat paint before heat wraping the pipe so it's got a protective layer.:)
I was told to stay away from heat wrapping because although it reduces the heat being transfered out from the metal it also keeps the heat trapped underneath it. Without wrapping, your pipes etc would cool down after shutdown in lets say 30 minutes, but with the wrapping on they would stay warm for a lot lot longer supposedly accelerating the deterioration of your metal.
On the intercooler topic, I was told to use uncoated alloy piping from turbo to cooler as alloy is a good disipater of heat and then use HPC coated piping from cooler to manifold as it would stop heat penetrating the coooled air inside the pipe.
Sounds feasible in theory?
Interesting read, but im still not convinced...lol.
Firstly, in my application the turbo will be properly supported by a brace, not the manifold. So when at elevated temps, wont be under any mechanical loads from supporting the weight of the turbo.
Secondly i already have my manifold ceramic coated by Competition Coatings so the heat transfer thru the internal coat into the material is already reduced.
And getting caught up in the physics of things, if what he says about thermal friction is true, then the hotter exhaust manifold will be cooled by the exhaust gases that are at a lower temp. So i need someone to further explain this thermal friction as i have never heard that term before.
Lastly my experience with stainless steels and other materials used in the pharmaceutyical, petrochem industries is you have dramas when things have rapid rates of cooling/heating etc.
If something is cooled (quenched) slowly then it is usually more ductile, so resists becoming brittle and cracking. The thermal wrap would control the rate of cooling which stops undesirable metallurgical changes.
I think cooling is more critical then the heating, when i drive im always careful/mindful that even if my engine is warm i resist booting it until im comfortable the manifold is at a reasonable/uniform themp (i know it never will be but trying to minimise any warping by throwing 800deg Cgas at a 20deg C manifold especially considering stainless expands more then the equivelant mild steel)
I dunno...have to have more of a think, but i need to know what this thermal friction thing is. Is it simply a term for friction of gases ie energy is depleted from the exhaust gas due to friction with the walls of the manifold, and the frictional losses equate to temp increase?
  • 6 years later...
just been reading thread
intercooler insulating suggestions have been
  1. HPC coated piping high performance coating ( don't know what they are exactly )
  2. Neoprene ( wet suit material
  3. Fibre-glass / foil tape
  4. air con insulation tape ( used in buildings to insulate air con pipes over distances
  5. uncoated alloy piping instead of aluminium
hope i helped you
hopefully this will revive it
Just doing some more research. found a guy who has measured the difference in temperature
7 - 10 degrees ( don't know what car though but it says the return pipe goes over the radiator like aftermarket gts-t - gtt FMIC kit )
using oven mitts ?
Insulating the Return
Insulating the intercooler exit piping? Really? What happens when the turbo is operating hard and adding heat to the incoming air, so the compressed air is HOTTER than the underbonnet temperature.....
In that circumstance insulation would affect the temps negatively, as the ambient temp is cooler, in fact most the time it is. I never saw the point in heat shielding anything other than the exhaust.
Edited by Rolls
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
