By a cruise through wine country do you mean stopping at wineries? Cos that sucks IMO as most people wouldnt be able to drink.
An overnight cruise would be good but we also dont want people driving back to perth totally hung over!
We need a cruise where people dont all get lost and split up etc ;)
Or we could do a short cruise to an AWESOME location, do a massive photoshoot and have a bbq.
I vote to start the cruise @ Shelley Foreshore. It's 2minutes from Leach Hwy.
Also I have tools at mine on Barbican Street, SAU peeps welcome to use if they have dramas.
Otherwise jump in mine or another SAU car and enjoy the drive.
They have a BBQ area we could all chip in or BYO and stuff our gullets with rump beef yayyyy
Awesome location overlooking Pt Salter etc. Heaps of blinged up boats and terrific view, ample parking.
Great way to start a cruise and its a fantastic driving road (all 50km/h though, so be sensible-ish) along the coast until you hit leach hwy.
Then maybe take Welshpool Rd up until the hills? Lake Leschenaultia destination? I've never done Zig Zag so would be fun.
Come back to work on Monday refreshed :(
Just some thoughts !!
-dave
ps. happy to help out logistically to make this happen.
Edited by dave_rb20
G'day all,
I'm new to all of this and I live in 'desert land' 1600kms north of perth but my father and I are going to be in Perth in June. I'm getting a few mod's done to my skyline and want to take it for a wrap somewhere once it's finished. Is there anyone who would be interested in meeting up in person (whether it's just to meet or to go for a cruise) between the 9th - 11th inclusive?
Also wondering if someone could suggest anywhere in particular for a good spot to drive where I won't attract attention from the friends in blue or somewhere to go for a spin but stay out of trouble???
Any feedback would be greatly appreciated.
Cheers,
Brendan
  • 1 month later...
G'day all,
Cheers,
Brendan
We tend to head out of the Perth metro and into the hills to avoid unwanted attention, plenty of good roads out there :P
  • 1 month later...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
